im messing with aligning my drive, hopefully bolting it up... and then i start thinking about this little guy... how do i connect the cable to this beast?!?
Then you need the bolt that has a smooth shaft to bolt it on, you could probably get away with a regular bolt and washers. The end uses a pin with a cotter pin to hold it on.
looks like just a clevis pin and cotter pin. thanks for the heads up on those morse cable adapters. ordered and on the way! hopefully adjustment will be easy for me.
