SOLD - 1999 35' Fountain Executioner
Havasu Catman
For Sale is a 1999 35' Fountain Executioner with two 540 cubic inch Custom Engines dynoed at 740+ HP each. IMCO SC Upper and Lower outdrives. Teague Oil Coolers, Sea Strainers, Alternator, Water Pump and Power Steering Brackets. Three New Optima D31 Batteries with Billet Boxes. Engines have 27 hours since new. Total hours on the hull are 363 hours. One hour on new gimbal rings, stainless swivel shafts with new bushings and seals. New gimbal bearings, U-joint bellows, water lines, outdrive oil lines and intermediate shift cable. All four trim cylinders are rebuilt. Trailer has six new tires. Engines and outdrives are freshly serviced and ready to go for this boating season.
540 Cubic Inch Naturally Aspirated Build Sheet
• Chevy Bowtie Tall Deck Block
• Eagle 4340 4.25” Stroke STD Crankshaft, Internally Balanced
• Eagle H-Beam Rods 6.535” Length
• J&E Custom Ordered Pistons (9.62 Final Compression Ratio)
• ATI Harmonic Damper
• AFR Heads
• T&D Shafted Rockers
• Ferrea Valves, Inconel Exhaust
• Comp Custom Ground Hydraulic Roller Cam
• Morel Hydraulic Roller Lifters
• Comp Valve Springs, Retainers, Locks and Push Rods
• Cloyes Billet Timing Chain
• Dooley Offshore Oil Pan
• IMCO Power Flow Exhaust Manifolds with Custom Double Walled Stainless Exhaust Pipes All the Way Out the Transom (Water Mix at the Exhaust Tips)
• MSD Marine - Distributor, Box, Rev Limiter and Coil
• Large Remote HP6 Oil Filter Adapter
• Double Pass Teague Oil Cooler with Brackets with -12 Oil Lines
• Sea Strainer
Dyno Results = 749 HP @ 5,500 R.P.M., 772 ft/lbs of Torque @ 4,500 R.P.M.
$75,000
DSCN6734.JPG DSCN6737.JPG DSCN6739.JPG DSCN6741.JPG DSCN6743.JPG DSCN6744.JPG DSCN6746.JPG DSCN6750.JPG DSCN6753.JPG DSCN6756.JPG DSCN6757 (2).JPG DSCN6758.JPG DSCN6762.JPG DSCN6769.JPG DSCN6770.JPG
Havasu Catman
Boat is still for sale. I just received the document from the Coastguard in my name. Any interest?
Havasu Catman
PRICE REDUCTION
New price $70,000
I built these custom engines and did all the HP rigging on the boat. I also rebuilt the transom assemblies. The previous owner passed away and I purchased the boat from his wife to help her out. I have no use for this boat and would like to see it go to a good home. I have a clear title. It is freshly serviced and ready to go.
Havasu Catman
Yes, they were installed on the boat the same time as the new engines. They were purchased brand new from Imco.
Not So Fast
Ive seen this boat and know the builder, top notch on all points !!!!!!!!!!!!!!! The boat would be at home in rough water as well as lake use, sleeping while moored over nite woud be cool also. Someone will be getting a BARGAIN 👍
NSF
Marios Metalworks
Any idea on length prop to trailer tongue as well as width at the goal posts?
Also can anybody chime in on egress from the helm to the bow? Can the top of the cabin door support weight?
Havasu Catman
I can't really measure goal post to goal post with the boat on the trailer. The widest outside width minus the removable goal posts is 8' 5". The boat fits in my 40' bay with about a foot to walk around.
There is a hatch from the cabin to the bow as an egress.
Havasu Catman
I am not sure of the top speed. When I did the engines I promised the customer 90 MPH. We guessed at some props and I lake tested it. When it hit 90 MPH I backed out. I never asked the customer if he went after a top speed number.
Planet 9 eleven
New Member
Where is the fountain located? I live in Oklahoma city and trying to figure my drive time?
Thanks Cory 4052107911
