Havasu Catman
- Jul 14, 2014
- 221
- 194
For Sale is a 1999 35' Fountain Executioner with two 540 cubic inch Custom Engines dynoed at 740+ HP each. IMCO SC Upper and Lower outdrives. Teague Oil Coolers, Sea Strainers, Alternator, Water Pump and Power Steering Brackets. Three New Optima D31 Batteries with Billet Boxes. Engines have 27 hours since new. Total hours on the hull are 363 hours. One hour on new gimbal rings, stainless swivel shafts with new bushings and seals. New gimbal bearings, U-joint bellows, water lines, outdrive oil lines and intermediate shift cable. All four trim cylinders are rebuilt. Trailer has six new tires. Engines and outdrives are freshly serviced and ready to go for this boating season.
540 Cubic Inch Naturally Aspirated Build Sheet
• Chevy Bowtie Tall Deck Block
• Eagle 4340 4.25” Stroke STD Crankshaft, Internally Balanced
• Eagle H-Beam Rods 6.535” Length
• J&E Custom Ordered Pistons (9.62 Final Compression Ratio)
• ATI Harmonic Damper
• AFR Heads
• T&D Shafted Rockers
• Ferrea Valves, Inconel Exhaust
• Comp Custom Ground Hydraulic Roller Cam
• Morel Hydraulic Roller Lifters
• Comp Valve Springs, Retainers, Locks and Push Rods
• Cloyes Billet Timing Chain
• Dooley Offshore Oil Pan
• IMCO Power Flow Exhaust Manifolds with Custom Double Walled Stainless Exhaust Pipes All the Way Out the Transom (Water Mix at the Exhaust Tips)
• MSD Marine - Distributor, Box, Rev Limiter and Coil
• Large Remote HP6 Oil Filter Adapter
• Double Pass Teague Oil Cooler with Brackets with -12 Oil Lines
• Sea Strainer
Dyno Results = 749 HP @ 5,500 R.P.M., 772 ft/lbs of Torque @ 4,500 R.P.M.
$75,000
• AFR Heads
• Sea Strainer
$75,000
