Steel Beam
Discussion in 'RD's Lounge' started by braindead, Sep 10, 2019.
  1. braindead
    braindead Well-Known Member
    612
    687
    Feb 15, 2013
    i want to put a steal beam in the garage for lifting engines and anything else, but not sure what size I need. I've searched the web, but cannot find anything that allows me to punch in the dimensions I'm working with to get an answer, without adding in numbers for deflection and static load crap that I have no idea what it is. All the forums I've read where somebody suggests a certain size beam, has a safety Steve pop up and totally negate the previous persons recommendations because his safety factor wasn't high enough for the load he's lifting.
    Specs
    I beam that will accept a chain hoist trolley
    15' span
    And can be up to 8" high
    Would like to have a 2000lbs lifting capacity.
    Anybody got any leads for me?
    Headless hula likes this.
  2. monkeyswrench
    monkeyswrench Well-Known Member
    4,490
    6,932
    Sep 7, 2018
    I'm looking at the same issue. The 15ft span is a bit of an issue. If you have the vertical clearance, I had looked into doing a truss setup to help support the middle. I'm sure there is an engineer type here that can help. I've been meaning to ask for my shop project:rolleyes:
  3. 74 spectra20 v-drive
    74 spectra20 v-drive 74 spectra20 v-drive
    1,178
    662
    Nov 27, 2008
    I have a swinging hoist in my garage that works great, complete BBC out on the end and no deflection at all. I will get some measurements when I get back home this Friday.
    braindead and monkeyswrench like this.
  4. Yellowboat
    Yellowboat Well-Known Member
    15,483
    5,613
    Dec 18, 2007
    Do you want to have the lift point in a trolley or static? It's a pretty simple calc, just need to know the largest moment.
  5. CoolCruzin
    CoolCruzin Well-Known Member
    2,184
    989
    Nov 17, 2008
    I do this
    It’s chained up till I slip in the 2 legs
    It heavy so I leave it up there .
    Thick wall 3” tube
    Pulled manny of motors out
    Just make it high for boat engines
    braindead likes this.
  6. Done-it-again
    Done-it-again Well-Known Member
    2,855
    2,144
    Apr 3, 2016
    If you only have 8” clearance then 8” WF I beam either 18 or 21lbs per foot are your options. These have less than 6” flanges that your typical trolley ride on.
  7. Rayson1971
    Rayson1971 Well-Known Member
    506
    656
    Nov 23, 2017
    I just checked mine and it's 8" tall 4" wide spanning just shy of 15' being held up 11' high by what looks like 4.5" o.d. steel pipe. I have lifted everthing with . Boats, motors , outboards .
  8. SJP
    SJP WHTBRD
    4,911
    3,909
    Sep 25, 2007
    This came up before but I had this load calc and engineered. I ran two beams and my gap is 22.
    Boat211, nrbr, Sunset and 6 others like this.
  9. MotiV8
    MotiV8 Member
    24
    22
    Feb 12, 2019
    I designed a roll around crane for 4,000 lbs and used a S8"x18.4 narrow flange beam, but the span is only 10'. You would probably be okay with that beam @ 15' if you were to maintain 2k lbs max. The other crane I designed was for about a 14' span (same load) and I used a S8x23. Either of those beams would work fine for you, but I would use the S8x23 for safety's sake. How are you planning on supporting the beam? That could be more important than the beam itself given your relatively low load.
    As a side note, I like narrow flange beams for horizontal beams as the wide flange beams cost more and you don't get much strength for the extra price. Just my $.02.
    CoolCruzin and Done-it-again like this.
  10. rrrr
    rrrr Well-Known Member
    7,711
    10,937
    Dec 19, 2007
    Wow. Your shop makes me itch for some runs on one of those, no, all of those stand-ups. They are beckoning me.
    It's too bad I'm an old broken down fugger, instead of a fit and strong rider that could take on a challenge. Those days are long gone. :D
    Jeezus, this sounds like one of those "Gather around the tree stump, children, and I'll tell you a story of how I used to ride in twenty foot wave sets that captured the best riders around and then spit out their board shorts, the only thing that remained after the sea swallowed them whole." :D :D
    SJP likes this.
  11. Carlson-jet
    Carlson-jet Well-Known Member
    4,811
    3,366
    Dec 19, 2007
    So with just an I-beam with a span of 15' with proper support on both ends and maybe stabilizing in the center 4x6 is plenty @ 2k lbs. providing the trolly is capable. That is just a 1 ton hoist. It doesn't hurt to put gussets at the uprights
    If you want it to be a jib you are going to have to step up to a 5X8 or 5X10. What you use for a Mount/post is another question.
    I've made, installed, moved, torn down and reconfigured many.
    monkeyswrench and Mandelon like this.
  12. rrrr
    7,711
    10,937
    Dec 19, 2007
    Ask @Headless hula. He built a shop trolley hoist with the same specs you listed.
    Sunset and monkeyswrench like this.
  13. TripleB
    TripleB Well-Known Member
    1,326
    1,929
    May 27, 2017
    Try this
    buck35, Sunset and monkeyswrench like this.
  14. Old Texan
    Old Texan Well-Known Member
    23,249
    23,329
    Dec 19, 2007
    buck35, braindead and jeteater1 like this.
  15. Headless hula
    Headless hula Well-Known Member
    9,311
    17,673
    May 24, 2016
    I recieved lots of good info, and even more CAUTIONARY advice.
    I ended up using a used I beam that was undersized from a local scrap yard. It's what was convenient and damn near free. (Had less than $100 in the whole deal. )
    If I would have had customers or the general public anywhere near the damn thing, I would have followed the more cautious advice given. However, that wasnt the case, and I used what was "layin around" worked fine for my purposes.
    Here's a 5.7 and a 4.3 (both with all the marine dress) dangling precariously side by side.
    Individual results may vary, and don't try this at home. :eek::D
    Wheeler, rickym20, Sunset and 6 others like this.
  16. Old Texan
    23,249
    23,329
    Dec 19, 2007
    Note to all. The span is a determining factor in holding the load safely at mid span. But also always check the lower flange loading per pair of trolley/crane wheels. This is often overlooked even by engineers. Steel books give this number and it should be considered. Hoist and trolley data includes this number in engineered drawings.
  17. TITTIES AND BEER
    TITTIES AND BEER Well-Known Member
    8,789
    4,899
    Sep 28, 2007
    I just gave 12 -4” x 16”+20’ away the other day on my site , new steel
  18. norcalLmo
    norcalLmo Well-Known Member
    594
    312
    Aug 29, 2011
    Just my 2 cents: I went to Harbor Freight - instead of using their 7Ft I-beam I went to an Iron Yard and bought a 12ft beam and welded some plates that matched the uprights on the HF stands - works great - adjustable - lock-out saftey and for under $800 bucks - you can lower the cross beam and slide it into your garage - it's on wheels as well
    Just a thought - using existing wood beams in a garage = 911 calls - just sayin LOL!
    Wheeler, Sunset, SJP and 3 others like this.
  19. braindead
    612
    687
    Feb 15, 2013
    Trolley lift and be able to roll it to the side
  20. braindead
    612
    687
    Feb 15, 2013
    Good to know about the narrow flange beams. Don't need it to be mobile at the moment, so we're putting it up on top of the garage walls with 4x6 posts underneath each side and welding some plate steel to each side of the beam to be able to bolt it to the 4x6 posts. The garage is a giant shear wall on all 4 sides so lateral movement won't be an issue.
    Thanks, beams sitting On top of a wall Sitting on 4x6 posts with plates welded to attach to the posts.
    That's exactly what I was lookin for, thanks!
    That's a dam good idea, I'll have to look into that. Thought those only held 1000 lbs tho?
  21. Done-it-again
    2,855
    2,144
    Apr 3, 2016
    We have done a few beam/trolley work for a customer..
    Wheeler and Carlson-jet like this.
  22. Spudsbud
    Spudsbud Well-Known Member
    1,525
    1,621
    Jun 3, 2012
    A suggestion. build 2 A frames, like a swingset for the beam. Get a set of industrial casters from grainger. Plate on the bottom of each A withwheels so you can roll it around for easier use.
    Yes, cost a little more but way easier to use.
    nrbr likes this.
  23. mash on it
    mash on it Beyond Hell Crew
    1,174
    1,319
    Jan 26, 2011
    I use one of these.
    Portable. Heavy duty winch.
    Dan'l
    Wheeler likes this.
  24. Headless hula
    9,311
    17,673
    May 24, 2016
    Cheater....lololol....
    mash on it likes this.
  25. Old Texan
    23,249
    23,329
    Dec 19, 2007
    There are a number of material handling outlets that one can buy Gantry cranes same cost and cheaper than going this route. I sold this stuff for 35 years and there are many out there which are built very well for light duty usage.
    Since you mentioned Grainger, they have them in their catalog also. Cost is a bit higher but they come complete with casters matching capacity.
    https://www.google.com/search?sxsrf...&ved=0ahUKEwj-rsijz8fkAhUMIKwKHcQfBLMQ4dUDCAc
  26. HNL2LHC
    HNL2LHC Well-Known Member
    2,192
    2,111
    Jun 25, 2018
    Not sure if you have everything dialed in yet. If not I found something that could help you. Maybe wood might be the better direction......
  27. SixD9R
    SixD9R Well-Known Member
    399
    917
    Mar 16, 2019
    Red neck engineering at it finest. And very safe as well. Popular science story right there.
  28. Carlson-jet
    4,811
    3,366
    Dec 19, 2007
    Not giving a fuck, is an art. lol.
    :D
    SixD9R and HNL2LHC like this.
  29. buck35
    buck35 Well-Known Member
    3,531
    2,945
    Jan 27, 2015
    :eek::eek::eek::eek:
    HNL2LHC likes this.
  30. RichL
    RichL Well-Known Member
    656
    526
    Jan 14, 2017
    Probably OSHA approved too.
    :rolleyes::D
    HNL2LHC and SixD9R like this.
  31. 74 spectra20 v-drive
    1,178
    662
    Nov 27, 2008
    I scored this set up from a friend of a friend about 10 years ago or so. If anyone new Lloyd of Lloyds crank grinding in Bellflower, this hoist was his until he retired. I have 10' ceilings in the garage and this was 8' so I mounted on a 2' x 2' concrete pad and tied the top to a joist. vertical beam is 6x6 I beam and horizontal is 6x3 and is 9' long. I love the swivel as I can pull a motor and just swing it around and not have to move anything. the horizontal beam just brushes the dust cover on the lights with an engine hanging on it or not, I was amazed at how rigid it is.
  32. Old Texan
    23,249
    23,329
    Dec 19, 2007
    It's called a compression braced jib crane.....
    scottchbrite and Headless hula like this.
  33. Boat211
    Boat211 Well-Known Member
    1,258
    416
    Dec 20, 2007
    27CFE560-1F35-48D1-8BD3-3238365764A2.jpeg 2C2E3BDF-4693-4505-9F07-37C6EDB1ADBC.jpeg 48D7C944-A642-4D9A-BEEA-9C54E5750F4A.jpeg 6E3815F2-5357-4D20-A010-BA84521A10EB.jpeg CC7997CC-952A-49D1-8241-795AD91364A8.jpeg Here is my setup. My biggest complaint is that the ceiling height is too low for many applications. But all in all, I have used the heck out of it. It spans 14’ and is supported in the walls by 4x6 post on each end. I also have 2 4x4 cut to length for real heavy lifts. I once had a Bridgeport mill hanging from it.
    HNL2LHC and SJP like this.
  34. braindead
    612
    687
    Feb 15, 2013
    Now that's just showing off, but I like it!
    Thanks for the dimensions, I think we're gonna go a little overkill and get an 8". Only wish we would of put it in when we built it, woulda been a lot easier!
  35. braindead
    612
    687
    Feb 15, 2013
    That's freakin cool! Can I have it:D
  36. braindead
    612
    687
    Feb 15, 2013
    Hold my beer!
    HNL2LHC likes this.
  37. braindead
    612
    687
    Feb 15, 2013
    Thought about that, but don't have the room to store that giant thing for as little as we're going to use it
  38. braindead
    612
    687
    Feb 15, 2013
    Show off!
  39. HNL2LHC
    2,192
    2,111
    Jun 25, 2018
    Nice that is so cleanly done. I assume tied to the alls of the structure it will help keep it from racking. :thumbup:
  40. Boat211
    1,258
    416
    Dec 20, 2007
    So far so good. Been up now for about 17 years. It doesn’t get used often but real handy when you need it.
Share This Page
