PDQH20
- Nov 10, 2017
- 39
- 75
UFP 9.75" 5x4.5" lugs discs brake hub and rotor with stainless set screw. Is it toast or can it reasonably be saved?
What say the master machinists?
I have literally never had an easy out work on anything except something that was finger tight, i don't even bother with them any more. Now you are screwed though, a left handed drill bit would have been a much better bet, but they don't work to well going into an easy out....
Heat it up to where it sizzles water and drop it into a coffee can of 50% AFT and 50% Acetone, and do it outside, away from any source of ignition as it will boil and the vapor that comes off is INCREDIBLY combustable.
Then go to work with a left hand drill.
That being said, the rotor is probably cheaper than going through all of that.
I’ve gotten lucky a few times shattering the broken easy out with a punch and then clear out the shards. Resume attacking it with a left handed drill bit
I'm happy reading this thread.. LOL
I always figured I was a fucking idiot, because I've literally NEVER been successful with an EZ OUT.. LOL I normally will drill em, or I'll take a small punch and back them out that way.
It would be easy to get out with a carbide endmill, providing the tool extension wasn't so long.
Where are you located?
It wont get a broken ez-out removed but for those that dont have success with extractors this is the only set you should ever use.
Straight-Flute Extractor, Drill Bit, and Drill Bushing Sets
The extractors in this set are matched with the right drill bit sizes as well as bushings to help you drill a centered hole into the broken part. The straight-flute shape provides the tightest fit and the most contact but also causes the most expansion. Insert directly into pipe or drill a hole in a fitting. Tap the extractor in with a hammer and turn. The part will back out without damaging the threads around it.
For Screw
No. of Extractors
Included Thread Dia. Size For Pipe
Size Overall Lg. Turns
With Material No. of Drill
Bits Included Drill Bit Size No. of Drill
Bushings Included Container Type Each
For Right-Hand and Left-Hand Threads
Right-Hand High-Speed Steel Drill Bits
5 0.24"-0.56" 1/4"-9/16" (M6-M14) __ 2 3/8"-3 3/4" Wrench Steel 5 1/8", 3/16", 1/4", 5/16", 11/32" 10 Plastic Case 2565A2 $104.60
14 0.24"-1" 1/4"-1" (M6-M24) 1/8-1 2 3/8"-4 3/4" Wrench Steel 9 1/8", 3/16", 1/4", 5/16", 11/32", 7/16", 1/2", 5/8" 40 Plastic Case 2565A1 534.35
I'd say for the amount of time you'll spend removing it, replacing it would be the way to go.
A ton of heat is going to be the best bet now, if you can get the EZ out out of there.
Wear safety glasses. Those ezouts explode when they shatterTry the hammer and pin method as mentioned, it typically will shatter after some good hits. Gonna need to chase the threads with a tap when you're done getting the set screw out
Well I'll be damned, Jerry's is still there. They pulled my ass out of the fire many times back in the day!!! Good for them.
With all the time invested trying to get it out I would just opt for a new hub as well. $52.00 at Pacific Trailer.
https://www.pacifictrailers.com/pro...fp-db-35-9-75-zinc-plated-5-on-4-5-3-7k-41019
This place (Dycorp USA Inc) is closer to you and probably cheaper. Your time is money. Keep the old one for a spare to use in emergencies.Thanks, Big. Pacific Trailers has been my fall-back plan. It's tough for me to jump to replacement if I can fix it. At the price though, how much time and effort you can afford to invest? Been trying to get hold of their parts dept to verify stock all day. Will try again tomorrow.
https://www.google.com/search?q=tra...afari#istate=lrl:iv&rlimm=6721094449516955305
