Suspension equalizer disaster
Tahoe540
I was putting new grease and checking the bearings on the trailer when I found this. I believe it has been broken for some time but finally broke when we took the boat on a dirt road. I found the other side to be in very bad shape as well. After a lot of looking there are no straight 6 1/2" straight equalizers that I can find online so I am assuming these were made for the trailer as a custom job possibly? The design and materials does not seem fitting for the weight of the boat. I am planning on using solid stock 1 3/4" and drilling the holes keeping the current geometry the same. Any reason this would not work? As I really do not want to redo the whole suspension.
Icky
Have you looked on etrailer? You can email them as well,
Looks like it wore through the bushings a long while ago.
wsuwrhr
The Masheenest
I am surprised that isn't available from a trailer supply place.
A solid part would work, it will be 25-30lbs though.
A piece of tubing could be made just like you had.
wsuwrhr
The Masheenest
with your boat upside down and your truck on its side. ;) Right now it is just something to fix.
Who made the trailer? Check with the boat manufacture too....just some ideas.
A simple drawing could be made and taken to any fab shop and they can do up a pair pretty quick for you.
If you cant get help in Reno, Id call arrow trailer supply and see if they can help.
909) 986-3737
Tahoe540
909) 986-3737
Well I appreciate the suggestions and the help. I have everything to fab something up just thought it would be stronger and easy to just drill 6 holes. Should only be around 7lbs per side with out holes.
Icky
Are you going to use some sort of bushings in the holes? Bolts that have the zerks already built in?
wsuwrhr
The Masheenest
I think you were talking about a solid bar, not tubing.
7 lbs would be tubing.
Tahoe540
Yes, I am replacing all of the bolts and the center will get a grease fitting bolt this time.
renodaytona
Dam, definitely looks as though the bushing was worn out long ago. Trailers are generally the last thing we think about when there is all kinds of other work going on.
Tahoe I have an off topic question for you, do you have access to a tall A frame hoist or gantry crane?
I agree, the original part was not designed correctly. I looked at mine, and they are solid steel.
