sangermike
- Dec 21, 2007
- 330
- 28
while I have the trans out I was wondering what trans oil everybody likes to use in thier tubo 400. this is a art carr deal blown bbc in a 21 RAYSON.
Not really, I use a Lokar that bolts to the midplate and doesn't leak!
thats my next queston, how many quarts without the converter and stock pan, I did buy a deep pan that im adding 1 1/2 quarts. also i read another thead where the guys at prime marine liked using the cork gaskets on the chrome pans. any thoughs
Are you running a dampening plate or solid adapter? Good info on the oil.
I just bought a solid adapter for it.
heres the adapter i bought, not sure what brand it is I bought it from a PB member. ill bolt it up to a TCI flex plate
You need to check if the length is right on your drive. If your running a 3/8" mid plate take that into account. If it's to long it will put pressure on your crank and take out you bearings.
That's the same one I had.
Sent from my iPhone paid for with Union money.
dave, do you know who make's this unit.
do you have a link to that tci plate
If you use the TCI try to find a steel not aluminum flange. I had an aluminum one go bad.
