The Outboard Church
War Canoe
Stainless Member
Meet Sandy Weaselsqueezer
Sunday’s sin.
KingofBeers
And it wouldn't be a proper ride in my sled without a little rinse off while I pretend it was a bigger boat than it actually is.👌 East side of Franks Tract was a little sloppy when we made our way back to Discovery Bay at the end of the day.
n2otoofast4u
And it wouldn't be a proper ride in my sled without a little rinse off while I pretend it was a bigger boat than it actually is.[emoji108] East side of Franks Tract was a little sloppy when we made our way back to Discovery Bay at the end of the day. View attachment 982165
LMFAO.... pretty sure I’ve seen this same picture before.
lake p.a.l.
And it wouldn't be a proper ride in my sled without a little rinse off while I pretend it was a bigger boat than it actually is.👌 East side of Franks Tract was a little sloppy when we made our way back to Discovery Bay at the end of the day. View attachment 982165
Incredible pic!! This 21 Liberator was made for this.......
stoker2001
AHQVegas
Been on here for a little bit but never saw this thread.. had to join in . Heres a pic of the float, Mach 26 with 300xs's prepped with DBR kits . Home lake is Havasu .
War Canoe
Stainless Member
Welcome to the Church !! Plenty of Church members near you in Havasu to go run with.
AHQVegas
Nope, I wish new interior in and getting ready for color change on boat
Isnt that winter time stuff ? lol What color you going with ? Im working on props right now, Im at 15.8% slip at 93 MPH and 6300 RPMS
rpmsrup
LOL ya it is, and its been going on foe a while also did full trailer rebuild, going with blue and orange or possibly blue and pink not sure 100%, what props are you running now
War Canoe
Stainless Member
Welcome to the Church....please dig up the images when this was a triple. Insane!!!
Rdcdetailing
New Member
That had to be insane!!!! How does it run with 2 XS ? What props work best for you? Spin them in or out?
honestly fastest I have ran it was 106 with the optis. Will run that any day. Spin in and have 14.75x32 5 blades. Was something to get the boat on the water and just haven’t messed with it since. Would love to change it up and do some real testing
Bullhead bully
Try 34 vented Bravos. They worked awesome on my 22 with 300XSs. 112-115 Anytime. I still have a set in Havasu if you want to try them. I have 32s as well.
stoker2001
wonder if James 26DCB with 300X could turn those?he runs 32 by15" humback cleavers now turning 6800 on a good day.he has H20 pickups on bottom of boat,so he runs close to 3" centerline PS above bottom.Maybey have WC grab them on next visit?
Ragged Edge
Man in the Box
Been working on the Tuff putting new Imco steering in. Mounted the helm a few days ago, had to have some holes filled in the dash because the hydraulic portion is HEAVY, just mounted the hydraulic pump yesterday.
I'd mount her next but my wife might complain. 😁
AHQVegas
Did you say PINK !!?? lol MANNNNNNNN . I need to do my trailer, who did you use ? Im still on the 30P lab Bravos , with 15.81% slip its time to finally get this thing lined out . motors are out of break in and she was screaming at the meet up asking for more !
War Canoe
Stainless Member
Did you say PINK !!?? lol MANNNNNNNN . I need to do my trailer, who did you use ? Im still on the 30P label Bravos , with 15.81% slip its time to finally get this thing lined out . motors are out of break in and she was screaming at the meet up asking for more !
That slip should be at or close to 10% with a clean set of bravos....make sure your engines are straight up and down 90 degrees...that will assure effective transfer of power. I’d bet a nickel you are trimmed out a little too much.
On dry , level land, with the boat on the trailer, get a couple levels and level the trailer...
Put a level on the cavitation plate and adjust trim until you are a perfect 90 degrees straight up and down. Measure from the center of the prop shafts to the floor on both engines...hopefully identical measurements...
Measure from the bottom of the boat to the floor. (This will tell you engine height relative to the bottom.)
Don’t touch the trim and go launch it...
Get it on plane and run it up to full speed and then check your numbers ....
Use a couple sources for mph, a hand held gps is often more accurate than a Speedo.
Ill bet your slip ratio drops 5%
Keep us posted.
War Canoe
Stainless Member
Depending on your gear ratio, these numbers should be accurate at a 10% slip.
Berdes
Hell of a turnout the past year. The run south into Alabama into Guntersville is awesome too
Would love to hear more about that run and it's organizers. Just moved from "up north" to Southside on the Coosa river.
