Trailer tires?
Discussion in 'Trailers' started by convincor, Jul 4, 2017.
  1. convincor
    convincor Well-Known Member
    142
    52
    Jan 7, 2008
    Need to replace tires on my trailer. Does anyone make a trailer specific tire in a P235/60R14? If so, any preference on brand?
  2. Runs2rch
    Runs2rch Well-Known Member
    6,152
    3,526
    Jun 10, 2013
    Light truck is usually the way to go except with 14's.
    Check out Maxxis 8008's and the new Goodyear Endurance. The Goodyear comes in 8 ply, has an 87mph speed rating and is made in the US also.
    convincor likes this.
  3. convincor
    142
    52
    Jan 7, 2008
    Just went to tire rack and it says that size isn't available in the endurance
  4. Runs2rch
    6,152
    3,526
    Jun 10, 2013
    You sure that is the size?
    A 215/75/14 is a little narrower, but a hair taller.
  5. Runs2rch
    6,152
    3,526
    Jun 10, 2013
    What are you using now? BFG T/A's?
  6. convincor
    142
    52
    Jan 7, 2008
    The original tires from extreme was Roadmaster Rampage GT 235/60/14.
    Tires were replaced once with 215/75. The spare is still original. Just like the look of the wider tire and lower profile. It has a wide wheel.
  7. Runs2rch
    6,152
    3,526
    Jun 10, 2013
    Run the 215/75/14. More common if you needed one on a road trip.
    That is exactly how mine look. You are getting the whole tread on the ground without stretching the tire.
    RitcheyRch likes this.
  8. convincor
    142
    52
    Jan 7, 2008
    I'm sure availability was the reason they replaced them with the 215/75's and I will also if I can't find the 235/60's.
  9. renodaytona
    renodaytona Well-Known Member
    2,974
    1,052
    Aug 17, 2010
    Been researching this my self for a week or so trying to find something comparable in a 215 60 14. Also trying to decide if I should just move up to a 15" wheel, quite a few more tire choices in 15".
  10. Runs2rch
    6,152
    3,526
    Jun 10, 2013
    Depends on your setup. If you need more load carrying then the 15's for sure. I have 14's now. 21 ft boat on a triple axle. 1860 a tire is what the 6 ply's I run are rated to.
    6
  11. renodaytona
    2,974
    1,052
    Aug 17, 2010
    Current setup is 25' Daytona on a triple axel competitive trailer. Been running the BFG's on the 14" Boyd's aluminum wheels for years but I want to change it up and it's time for new tires again. Also looking at installing new fenders so I can also raise them up slightly if need be for more clearance.
  12. Runs2rch
    6,152
    3,526
    Jun 10, 2013
    The 215/75/14 will be a little taller than what you are running. Same width. You might have room to raise your current fenders if they won't fit as is.
    renodaytona likes this.
  13. johnnyC
    johnnyC Well-Known Member
    299
    236
    Oct 15, 2016
    try looking at tire size 225/45/r17 extra load tires with a 17 x 9 rim make sure the rim is rated at least 2200 lb the 225/45 are rated at 1819 lbs each and are abt 3/4 in larger in diameter. American makes a rim 7 spoke that fits the bill, the tires i use are by sumitomo ( a Mercedes application w rated ) i put this combo on a triple axel trailer that had 235/60 15 load range d tires just make sure you calc your gross load to check the capacities
  14. 02HoWaRd26
    02HoWaRd26 Well-Known Member
    4,275
    4,637
    Dec 19, 2007
    I've got a total of 6 black 15" wheels with 215/75/15" tires im looking to sell.
    Four have maybe 40 mikes as well all are kept in the garage.
  15. Nail It
    Nail It Active Member
    25
    33
    Jul 6, 2017
    I have dealt with this on my old Mach 22 trailer which was 235/60/14s also. Carlisle is the only one who makes that size in a trailer tire now. My current Mach 26 came with brand new 235/60/15s Carlisle's on it and have had multiple blowouts. I always check tire pressure and run them at their Max PSI. Tires were only a year and half old and 2 let go on the same trip. Had to replace both fenders on the trailer and the rubrail on the boat after. So I'm done with Carlisle's. I just put on a set of 205/70/15's that my local tire guy recommended. With the Mach 22 not being that heavy I would just run the 235/60/14 BFGoodrich T/A radials.
  16. convincor
    142
    52
    Jan 7, 2008
    I ended up getting 235/60/14's in a Cooper. Looks so much better than the 215/75 with the wider wheel.
  17. renodaytona
    2,974
    1,052
    Aug 17, 2010
    Do you have before and after pics? I'm wondering how well this size would work/look on my set up.
Share This Page
