2FORCEFULL
- Jan 26, 2008
- 28,968
- 17,605
I THINK I KNOW THIS FOR FACT... as I read it on the internet....heavy boats like 4 blade props and tritoons should run @ 10% slip WOT...
more fiction....No way does a tritoon run at 10 percent slip.
more fiction....
with the front and rear doors open , and the right angle of attack, you have a magic carpet rideAnd no aerodynamics
????? faster or slower???You’re forgetting wave spanning ability between the two different length boats in your equation.
I have no idea Steve, just stirring the pot a little bit. But I do enjoy reading your comparisons.????? faster or slower???
gonna be interesting for sure.... getting the motors set to the right height for the props and testing 3 and 4 blades...I'm thinking the motor could be a hole higher with four blades...I have no idea Steve, just stirring the pot a little bit. But I do enjoy reading your comparisons.
Steve, I've done a bunch of prop testing on similar boats. I'm like you, if my boat has the potential to go 29.5 mph then that's what I want to see! As you know, props are all different and they react differently on different boats. Basically the best set ups I've found are large diameter/blade area 3 blades such as Merc Mirage. I was VERY surprised as to how efficient a Merc High 5 was on an outboard deck boat I had. Your results may varyEvinrude makes a prop, rx4... they say it's for tri tooms….????
and question,... anyone tried a 4 blade on a toon?
Ask Scott about a the Electric Jack off plate. Lol.gonna be interesting for sure.... getting the motors set to the right height for the props and testing 3 and 4 blades...I'm thinking the motor could be a hole higher with four blades...
The math is over my head. Our toon hits the limiter at 55 ish with a 16. Tested with a 17 solo (sales demo) was 60 on the nose so they dropped a pitch because we would always have a few people on board.
I want to try a 17 with the family and see if it’s better, or at least gets me off the limiter.
If you have one that’ll fit a mercury 400 I’d be interested if you are going to sell it once you nail down the right one for yours.
Friday I went from winsor to the avi casino,... on the way back pretty good head wind...so I put the top down,... cruised 50 not on pin...personally I think the motor needs to come up,...and think it will do better with a 4 blade... but, everyone pretty much runs them how they came....Sues Evinrude jumps on plane....and I think it's gonna be about 5 mph or more faster than my honda….I was in havasu this morning, got the windshield off, and last night we got it switched on to the triple axel trailer,....I didn't know catus didn't do service work,... but I dropped it off anyway this morning,.. there gonna install the bimini top, and warranty the dash, the vinyl covering is coming loose... so probley won't get it back till Tuesday....then I'll go run it to get a base reading,... I have a 17p and a 19p prop to try...While spending a grand on a new prop for 1 or 2mph in a toon doesn't appeal to me, I am curious what your water testing of different props shows. Pretty sure most of us roll with full bimini up so that has to take away from the top end also.
how much are they???Ask Scott about a the Electric Jack off plate. Lol.
Go see Scott. Lol. It's our little mph secret and Berkshire learned that from us for the Twin engine boats[emoji6][emoji8]how much are they???
Question…. does any one know how far below the bottom of the toon the prop shaft should be????
Put a straight edge out from bottom of the Toon to drive caseI'll take a picture of mine tomorrow when I get into town but I know it sits pretty high with minimal draft on plane.
and where should the prop shaft be from there...I guess there is a lot of variables when it comes to toons and prop shaft heights and props... thinking all I know about boats and props is not gonna apply ...Put a straight edge out from bottom of the Toon to drive case
That's the beauty of the Jack plate. You can bury the prop deep for turning (Tubing kids) and then raise it up high for better top end speeds. Now the fun begins because I haven't takin a lot of time to play with the different combinations of props and the jack plate heights for the differences in how they perform while plates down or up with different props.and where should the prop shaft be from there...I guess there is a lot of variables when it comes to toons and prop shaft heights and props... thinking all I know about boats and props is not gonna apply ...
now throw the notched 27'' gt in the mix....confused here....when you first hang the motor... do you straight edge the bottom of the toon and sit the motor at a specific measurement...That's the beauty of the Jack plate. You can bury the prop deep for turning (Tubing kids) and then raise it up high for better top end speeds. Now the fun begins because I haven't takin a lot of time to play with the different combinations of props and the jack plate heights for the differences in how they perform while plates down or up with different props.
So you could try out different style and pitch props to see. Usually larger diameter props work the best for Toons.
We usually see a 3 to 4 mph top speed with the Jack off Plate. [emoji12]
For a fixed bolt on motor I never played a lot with the height with the straight edge off the bottom but I have seen when running at speed the motors seemed a little deep and could come up a hole. But if they set them up high then the people complain about blowing prop out.now throw the notched 27'' gt in the mix....confused here....when you first hang the motor... do you straight edge the bottom of the toon and sit the motor at a specific measurement...
also, gonna say this...you get a lot of bang for your buck wth the godfrey / Evinrude @ only $59,999
