i have a 2002 superduty and the other night i shut it off and took the key out of the ignition and it didnt shut off till i pulled fuses. If anyone might have an idea it would be appreciated. thanks
Does it have an Edge computer? I have my truck set up the same way so when you turn the key off the engine stays running until it reaches its cool point setting. If you turn the key off and put your foot on the break it also shuts down.
i do have a remote start/turbo timer but i did try pushing the brake that didnt shut it off. i removed the alarm module and it still does it.i also tried an ignition switch which didnt work. i do not have the edge programmer. thanks for the responses.
