Bob Delozier
R&B Auto and Truck Center, Foothill Blvd. Fontana,
- Mar 17, 2011
- 51
- 9
Descriptions
1 $55000.
Freightliner 4x4 Quad Cab – AUTOMATIC - Overland / Chase or recovery Vehicle.
Very rare 4x4 , almost impossible to find anywhere
2004 Freightliner 4x4 crew cab Overland with Automatic Trans
FL70 Truck Super Single Falken G1378’s
Air Conditioning
Hi / Lo Ranges Transfer with Locking Front Axle
Carpet + Custom Interior
Super clean
Bench Seats ( seats 6)
Factory 4x4
Allison Automatic Transmission
Cat C7 engine
Aluminum wheels
New super single tires
Tinted windows
Light Bar
Storage Belly Box’s
CB Radio
LED Exterior Lighting
Lift Gate ( Motorcycle Rack included)
Nose Guard
Kenwood Stereo
Brand new Box with lift gate
Low Miles 68,007
• Box dimensions 7’x7’x14’8”
• Falken Tire’s GI 378s in what size? Manufacture date is 36/18- very good tread and shape, size is 38565/225
• Gear Ratio is 4:63
• Factory/Stock 4x4 configuration
This would be a great truck for an RV conversion or Overland truck conversion
$55,000
Link to more images: https://www.racingjunk.com/Other/18...rew-cab-4-dr-automatic-Trans-A-C-8-deck-.html
2-
2007 Freightliner 4x4 "Sport Chassis" Crew Cab with Sleeper,
-AC
-Electric Windows / seats
-M2 base
-Mercedes Diesel – 330 HP/2200
-Allison 3200 TRV Automatic Transmission
-Only 54,000 miles,
-Custom Leather interior with a walk through into a Unibilt sleeper for 2,
-Flat screen
-TV
-Microwave,
-Closet
-B&W hitch,
-CDL not required, always stored inside
-AF-8 8,000 lb. front axle with a 14,000 lb. Meritor FSD
-MVG 750R 2 speed transfer case that is air shift rated for 350HP and 7400 Ft. Lb. Torque
-Air Brakes with ABS
-10 Hole Wheel Ends
-Gearing ratio 5.13
-Front Air Spring Assist system
-Additional Parabolic leaf Springs to each side
-New adjustable drag link
-4 Brand New Wheels and Tires
- Wheelbase -----187’ center to center 291 total length
- Turning radius-
- Height of the deck---57’
- set up for gooseneck
Asking $105,000; trades considered. Call 909-478-4791
* We used a Fabco (Meritor now owns Fabco) FSD 14A Center Bowl 14,000# front drive axle with manual Warn lock out hubs. The transfer case is a Marmon Herrington MVG-750 (now called a T-20). There is a breakdown of axle and transfer case in a booklet we put together that is inside the cab.
Feel free to contact Todd at TULSA TRUCK MFG CO.
(https://tulsatruckmfg.com/)
Todd Turner
10318 East 52nd St
PO BOX 470321
PH: 918-627-5501
FAX: 918-627-8613
And verify everything that is being described herein this post.
Vin: 1fvacvdj27hhyo5168
Miles: under 55,000
Model: mm 1540425
$105,000.
3
GCVW is 66000lbs
Freightliner 4x4 Quad Cab with Sleeper-10ft deck- cummins 8.3 -79,000 miles $85000.
2008 Freightliner 4x4 ( it’s the only one available anywhere)
Pre DEF Cummins ISC 8.3 diesel Motor with a new turbo
Allison 3500 Automatic Transmission
Four Wheel Drive with Air Lockers
Air Brakes and can be set up for air brake trailer
Air Ride suspension and air ride Cab
240 inch wheel base
11 ft flatbed with Gooseneck Ball
124 Cab to axle and 6" Sleeper to axle measurements
Like New 42 Heavy Duty, aggressive, Tires on Aluminum Alcoa 22.5 Wheels
Truck currently has 4 seats plus the sleeper. More seats could be added if needed
It’s very easy to drive
*Just Serviced and replaced all Oils Transfer case/Transmission/front and rear differential’s, Brakes , bearings, fluids
Super Single rear
New Wiper blades
Quad Bucket Seating
LED Brake lights
46” inch Sleeper
Air conditioning
Kenwood Stereo
Backup Camera
Alarm
Heated Mirrors
Electric Locks
Electric Windows
Recently replaced Tires
New Carpet
Sleeper
Undercoating
LED LIGHTS exterior
Aluminum wheels polished
Trailer Brake
New Custom Exhaust
Locking Diffs (on demand) + AWD full time on demand
Rear Deck is 10’8” l x 8’ w
Clear clean Title
* GVWR dry 15,000lbs
Tires 90%
Wheel Base center to center= 20ft 2 inches
Overall Length 30ft
Height 9ft 6inches
MPG 7 to 7.5)
$85,000. Firm
Bob De Lozier 909 478 4791
Est. 1986
16020 Foothill Blvd.
Fontana, CA 92335
O: 909-829-1140
C: 909-478-4791
Certified Master Dealer- NIADA
AAA Certified Service Provider
A+ Rating with BBB
1 $55000.
Air Conditioning
Super clean
Factory 4x4
Cat C7 engine
Aluminum wheels
Tinted windows
Light Bar
Storage Belly Box’s
CB Radio
Nose Guard
Kenwood Stereo
Low Miles 68,007
$55,000
2-
-AC
-M2 base
-Only 54,000 miles,
-Flat screen
-TV
-Microwave,
-Closet
-B&W hitch,
-10 Hole Wheel Ends
-Gearing ratio 5.13
- Turning radius-
Todd Turner
10318 East 52nd St
PO BOX 470321
PH: 918-627-5501
FAX: 918-627-8613
Miles: under 55,000
Model: mm 1540425
$105,000.
3
GCVW is 66000lbs
240 inch wheel base
Super Single rear
New Wiper blades
Quad Bucket Seating
LED Brake lights
46” inch Sleeper
Air conditioning
Kenwood Stereo
Backup Camera
Alarm
Heated Mirrors
Electric Locks
Electric Windows
New Carpet
Sleeper
Undercoating
LED LIGHTS exterior
Trailer Brake
New Custom Exhaust
Clear clean Title
Tires 90%
Overall Length 30ft
Height 9ft 6inches
MPG 7 to 7.5)
$85,000. Firm
Est. 1986
Fontana, CA 92335
O: 909-829-1140
C: 909-478-4791
A+ Rating with BBB
