Vector v-Drive build. ( Goliath H20 )
Blownbillybob
jus gonna throw some random pics of my build to date up since the forum title has changed my full build is in the restoration section!!
All machine work done in house!!
wash11
Son of a.................
Great pics but would love detail of the build and changes etc too!
lenmann
Like Wash11 said, you lump it all together like that and you really get to see how much work these damn things are, how long, and twisty the journey can be.
On top of that, you have a range of skills (and tools) that aren't often seen around here.
So a couple of questions:
How close to done is it?
If I recall correctly you are up here in NorCal, did you find someone locally to do your polishing and where are you getting the anodizing done? Or are you doing that stuff yourself as well?
Blownbillybob
Yes I’m in NorCal. Polishing is being done at cantwells in SSF. And anodizing is done by Deans anodizing in Redwood City!!
didn’t mean to jam it all together but figured U could see the whole thing inthe other section and didn’t want to write a description for the thing all over again !!!! I could abandon the other page?? But don’t want to either !!!!
this is basically where it sits now have to make some interior changes before the motor goes back in !! And I traded my old blower set up for a gentry twin turbo setup but not running it on this boat so figuring a new blower set up ??
lenmann
Looking good.
Was your rudder originally offset to port? or did you move it over to clear the prop shaft?
Blownbillybob
groeper was asking what I used gel with a gloss additive and a gravity pressure cup spray gun!
74 spectra20 v-drive
Are you using the Morse Command II? I have that in my Spectra and an extra helm but cannot fine new cables, would like to have a spare set... did you find new cables if you are running that helm. Thanks
jstnoc
I'll be going through my storage soon and have some extra cables mostly all brand new. Send me a message with your lengths needed and Ill let you know what I have.
aaronschiada
Everything looks awesome. Just my two cents...get rid of that tiller arm! They are junk. the constant push/pull will eventually cause the bolts to oval out the holes and that is no bueno. I think Bergeron has the one you want that will sandwich the swivel connectors with material on both sides and a through bolt.
sintax
Correct! Single shear is generally not the best when you can run a double, esp when we’re talking steering.
welldigger00
Hey Aaron, I love your boat. Especially after seeing some loose hardware in the bilge. You ain’t v driving if you don’t have some hardware down there after a weekend.
sintax
So kind of like my old shovel head? If I can make it back home with 90% of my hardware attached I’m stoked. I started wire tying everything that would fall off.
welldigger00
Every single time I run my boat it seems like there will be one small washer, or nut. Like under a quarter inch. It’s a v drive thing.
Blownbillybob
superchatger back from polisher for jus a smooth metal finish no polish !! Gettin the decks surfaced and off to Texas for some coatings!!!
Blownbillybob
Had a friend do it !! He’s been doing hard line for like 35yrs !!!
I didn’t have time to practice on my own stuff and he has some custom benders for making tight turns !!!
Blownbillybob
So after a nice weekend at Halletts in Havasu!! Last yr !!
Had a little problem arise ???
Not sure why ?? Was not lean !! Nothing changed but fuel from down there ??
So did a couple preventative tricks to help with detonation!!!
Blownbillybob
Block is already machined and ready for assembly !!
Waiting on bearings !!!
Blownbillybob
Many many late nights on this 1 !!! WOW !!
Basically the opening on the Kuhl is the largest they cut into them and a reg 6-71/8-71 carb adapter would not fit and I didn’t want to sandwich in a alum plate under a carb adapter!!
So I designed this 1 and as U can see it was a solid alum block 2 piece and incorporates the regulator mount
The scoop is from a barn door injection that I modified to carbs !!
And 2 Pro-systems billet 1000s
BG regulator
AZLineman
Adjusting to retired life
That is just plain ass Bitchin. I’m also zooming in on all the cool shit hanging on the walls of your shop👍
Hammer
Can't believe you hurt it at HIH last year! Sweet ride, I was glad I was able to see it in person.
Blownbillybob
Yup not sure what happened ??? The engine had a full summer on it and 3 weekends with new set up and 1 day in Havasu ????
Blownbillybob
Made my own prop shaft seal deal !! Didn’t like what I seen on the market !!!
Adding a remote grease reservoir with ball valve to kill it when not in use !! Don’t like the ideal of getting in the boat every time I want to take it out with a grease guns and have to pull the interior every time also !!!
And also trying a silicone hose instead of the stiff black rubber 1.
AZLineman
Nice work and a very good idea. Bronze safety sleeve? Do you think the silicone hose will give you the rotational stability needed?
