buck35
- Jan 27, 2015
- 5,941
- 5,627
I have a 95 Merc 502 with this system. Repair, rebuild, or what's the deal to swap and replace? Mefi 1 .
Am I just screwed?
Am I just screwed?
Just some info - The gas tank is being filled from the return line that leads back to the tank. That return fuel is preheat as well and never stops returning. So the gas tank fuel is warm to a degree as well. Yes its a higher temp than when no return fuel to the gas tank. There is a huge misconception about the fuel never gets heated because you are returning back to the tank.. Yes this will help with vapor lock but so does the cool fuel system when they are properly maintained. Yes the VST was a bad design and yes you can use the weldon and or aeromotive or even I sell a fuel pump / and regulator with a custom bracket for a change over. Its all USA made as we and yes its has a return back to the tank as well. The least amount of issues in marine apps are wakeboats fuel systems because they all currently have fuel pumps in the gas tanks. All of them do currently and some since the 90 s. We rarely ever see vapor lock from these set ups. Basically the same as autos with fuel pumps in the gas tank.
