tonyoverthere
- Mar 5, 2021
- 49
- 40
Hi all. Picked up new-to-me jet boat and have a couple quick questions.
It has a 455 Olds and the Hardin 4-port thermostat kit in it. With this kit, water bypasses the engine and dumps directly overboard until the thermostat opens, then it allows water to flow through obviously, and the hot water coming out then dumps overboard. Previous owner had gate valve wide open. Should I still need to regulate water flow via the gate valve with this setup or leave it full open? Just dont want to over-pressurize the engine is all.
https://www.hardin-marine.com/p-80797-polished-stainless-thermostat-kit-for-455-olds.aspx
Next question: after the gate valve, there is a tee and another gate valve that controls water flow to the over-transom headers. Previous owner had that shut and ran the headers dry. I would like to run them wet. I believe I just crack that gate valve open very slightly, so as to only have a fine mist when above 1800 RPM, and pretty much dry below 1800 RPM. Sound about right?
Thank you!
Thank you!
