Water leaking in thru bilge pump?
Desert Mirage
I don't kow whether my flappers are shot and leaking or the water is leaking in thru my bilge pump hose. Has anyone else had this problem?
BadBlown572
A/B Team Liaison
If your bilge pump hose goes under water, it can gravity feed it back into the boat. When the pump is not spinning there is no force pressurizing the line and typically there is not a one way valve in the line. Bilge pump dumps should always be put in a place where they minimize the possibility of going under water.
However, if you have a set of flapper drains, I would bet that is your problem. Any debris that gets in them can hold them open. Also just over time, the seals start going bad and need to be replaced.
What Danny said, or your propshaft seal, shaft log base, or rudder log....
Marko
BIG member
Plug up the flappers and throw a hose in the bilge area and run some water in it. Wait and see where it leaks out. Tilt the nose up so the water stays in the back.
Beautiful Noise
If the water is coming in though your bilge pump hose you need a 1 way valve in the line :D I have one in mine BUT I cant remember which boat place I got it from:bash:
Beautiful Noise
OK.....I racked my Brain(ouch) you need a one way check valve in the line to keep the water from coming back into your bilge.... If this is your problem....West Marine has them :D
What size boat is this on btw? a low freeboard flat style boat, or a day cruiser?
Desert Mirage
It's on the boat below. very nice flat style vee hull. You can see where the bilge drain is. Thanks.
You definitely need a check valve with the bilge pump drain that low.
Desert Mirage
Are the pressures different on these and if so which one did you use?
