Tahoe540
- Aug 2, 2016
- 355
- 477
I am building a 496 for my 20.5 Hallett open bow jet boat.
The jet has been completely rebuilt and has a stainless A, bowl stuffer, inducer and a droop snoop with ride plate.
The parts I have for the short block are
BBC Mark IV 2 bolt block with a stud girdle. 4.310 bore
Crower 4.25 crank
Crower 6.385 I beam rods
Looking at a hydraulic roller with over .630 lift./Johnson lifters and will use stainless rockers
I have never ran oval port heads and the more I read on these heads and what rpm I will be using it for they seem to make really good power.
The heads I am looking at are no larger than a 320cc intake runner as this will not be a high rpm motor. I have seen some dyno videos online that show 290cc intake runner heads make over 600hp and good torque on this size motor.
Square Port
www.wilkesperformance.net
Round Port
www.westcoastoffshore.ca
They make a 320cc version but I think it might be too big for sub 6k rpm use.
I have always run large square port heads with higher rpm in mind on larger cubic inches from 540-582 and want to size these better for lower rpm use with the smaller cubic inch.
I am open to other suggestions.
I doubt this will ever turn over 5500 rpm with that A impeller and size of boat.
Crower 4.25 crank
Square Port
Canfield | WilkesPerformance | United States
Canfield Big Block Chevy CastingsRound Port
PROFILER SNIPER BIG BLOCK CHEVY 290CC ALUMINUM 24 DEGREE CONVENTIONAL PORT HEADS - PER PAIR - FULLY ASSEMBLED
PROFILER SNIPER BIG BLOCK CHEVY 290CC ALUMINUM 24 DEGREE CONVENTIONAL PORT HEADS - PER PAIR - COMPLETEwww.westcoastoffshore.ca
