aka619er
That Guy.....
- Mar 22, 2011
- 2,121
- 1,570
When I picked up my new to me Cheetah with a 200 outboard I realized the trim wasn't working. Solenoids would click as would the pump motor. I went through the pain in the butt process to remove and test pump and it just clicked even when wired straight to the battery. I ordered and received a new pump with a two wire setup that ran off relays instead of solenoids. Wired it up and reinstalled everything. When I went to trim the relays just clicked as did the pump with the press of the switches while the 30 fuse went immediately. I went and picked up a new fuse and 2 new relays as I heard they were cheap and a weak link and the fuse went again. This tells me the motor is seized and popping the fuses. Stupid me I didn't try to run the unit prior to just wiring and installing to confirm it even worked.
I have checked the power post relays and it is solid when pushing the switch as I just replaced both batteries this morning as well. Is there anything in the trim unit that could be frozen or bound up which would cause two motors to act this way even immediately after installing?
