Mercruiser Bravo Transom Specifications,
Bravo Production Transom, die cast gimbal ring
Bravo Magnum Transom, sand cast gimbal ring
Bravo HP Magnum Transom, no trim sender, solid hinge pins
Bravo Smartcraft Transom, Digital trim sender http://www.perfprotech.com/blog/articles/mercruiser-transom-assemblies
The biggest difference is the pivot pins and the way they are mounted, the ring and the helmet aren't much different than the way the pins fit in them, it's quite a bit stonger. The earlier HP transom assemblies didn't have electric senders for the trim gauge and a trim limit switch to limit upward trim
