vee-driven
- Aug 23, 2010
- 288
- 4
i need a prop shaft 1-1/8 aquamet preferred whos go the best price or wants to give me a deal on one? thanks
Do people really get a discount on parts for paying cash?
...and a brand new "Aquamet 22" prop shaft sheared flush with the strut barrel. Best of luck to you...
Any truth to the rumors that there is knockoff or low grade AquaMet 22 floating around that's being sold as the "good stuff" ? I trust that companies like Rex are buying legit stuff from legit sources. But I still worry when I read about owners claiming absolute failure at low hours. Are these failures a case where the AquaMet is simply too rigid and the massive torque of the Big Boy Motor is causing the cracking / shearing? I might be forced into a new shaft this year (which is only a few weeks away) and the last thing I want to do is spend a bunch of cash on the wrong prop shaft. I've got "boost" plans for the motor this winter and want to make sure the shaft I buy now is up to snuff for the future mods.
Aloha
unfortunately you can no longer get good k500 monel anymore (the canadian stuff), the old good stuff used to have a darker color on the outside of the shaft, and it would check out on the rockwell c-scale at around 34.... the new stuff rockwells at only 27 (made in italy) and is much softer and easier to bend. Bent a brand new one without even throwing a blade in fact..... so we were forced to switch to aquamet, which isn't as good as the old Monel K-500, but better than the stuff you can get today.I always use K-monel, costs more, cheap insurance!
Since my name has been brought up in this thread in relation to knock-off material, I will respond to set the record perfectly straight on the matter as the implication applies directly to my company. Although not named by the poster here or in several other threads over time on pb it is obvious and I'm damn tired of being stalked on any forum I comment on prop shaft info by this person. While this guy's certainly entitled to post whatever he wants I am entitled to respond as well and will do so. Most vendors shy away from confrontations. I don't. Never have, not gonna start. I have nothing to hide. I also don't hide behind weak implications when I have something to say. You wanna slam me, fire away. A few have done so over the years. When an apology or other measure is due I don't hesitate to handle it. Conversely when someone hammers me for something that just isn't true I will take them to the mat on the issue. Hotboat is littered with a few of these that figured I'd just roll over from customer pressure and potential negative press. This one's a bit different in that ex-customer is not seeking anything other than damage to my business at this point by continually implicating that the material I sell is somehow inferior.
We use the same high quality material we have used for 2 decades. The same material prominent v drive manufacturers and many vdrive race shops use. None of us have shafts breaking. If I choose to sell at reasonable prices rather than try to double my money on everything, that's my choice. We have sold over 300 prop shafts in the past 20 years. Out of those 300 shafts I know of two that broke prematurely including the one from the lot of material this single broken shaft of this ex-customer came from. The other broken shaft was several years ago and was replaced by the mfg. If shafts were breaking in mass believe me I'd know about it.
Ex-Customer contacted me and wanted the shaft replaced. That's a reasonable request. I contacted the mfg and they wanted the shaft back to test metallurgically for defect at the point of breakage. Another reasonable request. Again, it is not common this material breaks for no reason. Ex-Customer refused to do it (something that never gets mentioned), implied I was out to take advantage of him = unreasonable response. He was the customer, I wanted to get him handled. It was to be no dice. Returning the shaft to the source for testing was part of the warranty process. Hence no warranty occurred, a reasonable response by the manufacturer. He wanted me to take the money out of my pocket rather than comply with the warranty process and get the manufacturer to pitch in. Pretty much sums it up except for the several threads that ex-customer has now "implied" I sell bogus material carefully without ever naming Rex Marine. I've never sold bogus material and never will. Never have substituted a lesser grade material either for a 22 shaft as has been implied and never will. There are many reasons a shaft can break, one being a material defect which is very rare. I will not speculate on the install process of this broken shaft because I wasn't present for it. However I do know that many things can cause a shaft to break off due to improper install of propeller (by far most common cause of shaft failure) or even actual propeller failure shearing the shaft off at the strut. Most racers know their shit so there's a good chance there was a defect in this case. We'll never know though because it never got tested by mfg.
20 years, 300 shafts supplied, 2 broken, bogus material, nope. We handle warranty problems when they occur but not without complying with manufacturers warranty procedures and not without customer cooperation.
Now back to the thread starter's topic. I offered a good price (20%) off ONLY because I was overstocked on 1 1/8" material at the moment. It was his question, I answered it, and subsequently got hammered by a disgruntled ex-customer. It is common for suppliers to offer discounts when overstocked on something. Hell I have entire threads dedicated to stuff in this category. You see it all the time in all industries and to be the recipient of slamming because of a low price offer is absurd. Vee-driven and a couple others got swingin deals on shafts. I have a couple more to sell then that deal's over because I'll have the amount of material I feel is appropriate in stock for current market conditions. That is all I have until I read additional veiled internet bullshit disparaging my company, my products, and my reputation.
And folks wonder why most in the industry won't go near or participate in boating forums.
I'm not stalking you, you're irrelevant. From my perspective, there was no confrontation with you, I simply commented on a prop shaft thread and offered the OP a supplier for what he was looking for. If my relating the facts of what happened to me makes you uncomfortable that's not on me. NOT ONE WORD of my post was incorrect or inaccurate. The FACTS are not in dispute, the first prop shaft lasted 15 years, the third one has lasted a couple season and the Rex Marine broke on the first pass. Stevie Wonder can see something was wrong with that prop shaft. Maybe it was a fluke, material inconsistancy, whatever, it broke.
To be fair, Rex Marine did offer to "go to bat for me" with the mfg. However, the mfg had already said it was a racing related part and there was no warrenty. Not denying, you did offer to try with the mfg but you also made it clear Rex Marine would not stand behind it if the mfg didn't. We both know the mfg wasn't gonna stand behind it and it was pretty clear I wasn't gonna see a nickle back on the deal. My position was/is I BOUGHT IT FROM REX MARINE AND REX MARINE SHOULD STAND BEHIND IT!!! I'm a small business owner, it's what I do for my customers and what I expect when I'm a customer. So yea, I walked away from the deal since I didn't have a chance to prevail.
I had been a Rex customer dating back to when I was racing in the 80's and used to consistantly recommend Rex because of your support of racing. Moreover, I'm pretty easy to keep happy. All it would have taken was for you to simply offer store credit for the cost of the prop shaft and/or at least pretended to care about the customer. If Rex Marine would have been willing to do that, I would have shipped the prop shaft back in a heartbeat. Instead, you hid behind "manufacturer warrenty" and lost a customer.
As I explained in all the PM's we exchanged previously on the subject, this was never personal. I wrote it off as just differences in how we each view the customer/supplier relationship.
To be honest, I didn't wanna get into the he said/she said on the internet. I think we've both said our piece, so how about we leave it where it is.....
David I told you at the time there was a shot at getting it replaced if the material tested bad notwithstanding the shafting did not meet their minimum size for hp rating. There are few if any manufacturers that will consider warranty on an item without the item being returned for inspection / evaluation. Its pretty much the standard in business with all products whether they be performance products, engine parts, laser printers, lawnmowers, you name it. If they had replaced the shaft I'd certainly have given your money back or a replacement shaft at your option. If they'd have not replaced you'd likely have got that store credit anyhow. But we never got that far after refusal to return the shaft for testing.
Yes we certainly look at things differently. And the implied effect, even without mentioning my name, each time I post anything prop shaft related (such as the scenario above), is obvious in its intent, timing and placement when followed with your story and "best of luck to you" type comments. You told me at the time you felt it was just some sub-standard material instead of A22. That was not the case (while the A22 might have been defective) and when the implication in posts arise to that effect (that I would sell some substandard material vs A22) with my name attached or implied I will respond in kind to clarify the reality of the scenario.
Great post Mike. I have wondered for a long time who David was alluding too.
