chvynhra
- May 29, 2013
- 732
- 712
Who should I call to qoute building a workshop at my dad's place in Ontario? Anyone on the board build steel buildings? Can stick built be done for the same price??
that answer is gonna be no.... but most places won't lt you put up a steel building in re area's.... if you put up stick built the roof and stucco kills the price... if you put up steel, you have to frame walls and do a suspended ceiling to finish off the inside...so the price starts to even out... wind load and snow load drives the price up on steel, and you have to make sure it's calc'd to add the weight of the ceilingWho should I call to qoute building a workshop at my dad's place in Ontario? Anyone on the board build steel buildings? Can stick built be done for the same price??
Says they are in North Carolina?His company being in Ontario would probably have a lot of answers. If they do work in Ontario, hey probably have good connections with the city.
https://www.metalbarncentral.com/metal-buildings-for-sale/
I can build you a stick frame garage. As someone has mentioned it is more then a metal building. Also as mentioned you would need to check zoning to see if the metal building is allowed, they typically arent on smaller lots.
