Oh. The engine was efi turbo before I tore into it...it had an ancient haltech computer so I was planning to run it N/A with a carb for simplicity and cost. Should I try dry exhaust or new cam or blow through carb turbo?That's a hydraulic roller cam according to the card, not solid. Lobe separation is pretty wide for NA, and the duration may be a problem with your EMI wet exhaust.
I am camtarded....what is good and bad with my combo if I go turbo blow through?Obviously turbo will make more power. You could get that one re-ground, the the LSA will still not be ideal for NA even with dry headers. Best suggestion would be a new cam if you can find one. Isky just ground one for me in about 10 days (custom, not a shelf grind), but hold on to your hat when you hear current cam prices.
