D19
- Aug 13, 2018
- 2,316
- 4,582
Make new transom plates that will be a little bit taller, thicker and have countersunk bolt holes. Main reason for this is I had to clearance out the opening for the bigger HD Dominator jet pump and there is not a lot of sealing service over the pump I don’t like having a gob a bunch of silicone in there.
Rather than use a nut on the back of the bulkhead fittings that feed the motor and innercooler, the new plates will be threaded to accept -8AN. This should make reinstallation a lot easier.
While the plates are off I will pull the jet off and have my impeller cut down. The boat is currently running a 9.5" impeller and I think it’s too big. I am also adding a Prime a jet to the bowl because the pump is very tight and takes a lot of time for water to fill it up after watching. I hate being in “that guy“ who takes forever on the ramp while I wait for my pump to prime.
Sucking oil out the dipstick completely sucks so I will be adding a valve off the back of my Dan Olson pan. The pan comes with a -10AN Female fitting on the rear of the pan that I will have run to a valve that a hose can be attached to then ran through the bilge drain into a bucket.
Adding some trailer marker lights to the fenders so I can see the boaat night in my rearview mirrors. The fenders were originally fastened with self tapping bolts because I was in a hurry at the time, it is now being drilled and tapped for 7/16 bolts so the fenders will come on and off easily if needed.
All the marker lights were originally fastened with stainless screws and I think that was a little bit of a lame way to set it up so I will be drilling and tapping all the holes for 10/24 bolts. This will make disassembling the trailer a lot easier when I have it repainted next winter.
