cruzer
- Sep 25, 2007
- 363
- 30
I talked to Dave on Friday. He is supposed to look around his shop for one. However, this is the second time I broke this nozzle. I had it fixed the first time because the 4 venders I talked to could not get one from Dave. Dave does have some raw castings but I don't know what it takes to make one of those work.
I do know what I can get a polished Place for ($$$$).
That being said, you don't see posts of blown up Place diverters You might be money ahead buying the Place unit now... buy once, cry once. If that would have let go at speed (don't know that it didn't) on a fast enough pass, you could have had your hands full or worse. At the very least, I'm sure it was a suck day on the water because of it.
On the bright side, if you went over to a Place setup, you'd have the best part from the Aggressor setup which is the pump and wiring harness. They got that part right, but you're not the first person who has seen a failure in an Agressor diverter, and it's certainly not the first failed Aggressor cast piece I've seen. Dave is a nice guy, and I have his diverter pump and wiring setup on the shelf for my 76 Spectra project... Right next to the Place FTN diverter it will be used with
Chris
