- Dec 28, 2009
- 61,339
- 63,930
Is there anyway to get this off? Or do I have to wait for Edison?
Never opened one like that, not what we have in San Diego, but it's referred to as a Barrel Lock and I wouldn't be surprised if you could find a youtube video on how to pick or remove one, but probably not without damaging it.
I gotta ask why you want it off?
I think it's a felony to tamper with the meter seal as well.
pussyNeed to replace the main breaker. I'm not touching THAT one, with the meter still hooked up!![]()
Call Edison and tell them you need to make an emergency repair to your panel. They’ll remove the meter lock and come back in a week to relock it.
pussy
Take a ratchet strap and cinch it up tight. Then take the other end and tie it off to yore trailer hitch on yore pickup, then dump her in low, and punch the gas. Have yore olady video it, and post it up on RDP.
Nope...waiting on Pizza to get here for me and the kid. If you need a truck capable of the task as described, I have 2 you can choose fromLong Beach is probably on his way over right now, to perform this exact procedure.![]()
That's why I offered a GM or a Toyota.He owns a Ford it would probably bend the frame![]()
Which through you off from the sparky in the gloove...you guys are slipping...Classic RDP style in the flip fops
You started this thread around 3:30 and it’s not even 7:30. It’s Mother’s Day and Sunday how many people did you expect Edison to have staffed to run out and unlock that meter ring as their top priority? lol
Probably 4 guys covering a huge area, and at 3:30 if they weren't still out working they would have to call a guy out.You started this thread around 3:30 and it’s not even 7:30. It’s Mother’s Day and Sunday how many people did you expect Edison to have staffed to run out and unlock that meter ring as their top priority? lol
Some gravy OT right there.Probably 4 guys covering a huge area, and at 3:30 if they weren't still out working they would have to call a guy out.
DT 2 hr min. for the call out, unless they were already out But still DT. and Sat/Sun is a normal day until its after hrs.Some gravy OT right there.
I can see that in Havasu with extreme temps.To be honest, when my main shit the bed at the river, I figured the Mohave Electric people were going to take forever and charge a bunch. So, I treated those wires like plutonium, loosened the sets and gently wiggled the thing loose...while sweating like a pig, both scared and 110 degrees. Put the new one in the same way.
Later, I found out that if I'd called it in as a home with minors, elderly or ill, they'd rush out, for free, because it's a health danger in high or low temps... oh well, it was a learning experience. The stutter cleared in a day or two.
And make sure you tell them it's an emergency and you have no lights, with an electrician standing by. Trust me.
Right?pussy
sawzall wont cut it. torch will melt the plastic meter a piece of sheet metal by the meter and grinder small cuts only way"Sparkles" huh
Sawzall, cutoff wheel, torch![]()
Other than the leads from the meter are still hot, you pull the meter and its all ded.. unless you know some magic?You’re changing the main breaker, fuckin pull breaker and install new. Your makin this way more complicated than it needs to be. Hell if you removed the barrel lock, you think pulling the meter is safer then pulling the breaker?
amateurs
I mean in litterally every way pulling the meter is safer than changing a 200 or 400amp main breaker live that’s bolted down with 2/0+ aluminum conductors fed into it lol.You’re changing the main breaker, fuckin pull breaker and install new. Your makin this way more complicated than it needs to be. Hell if you removed the barrel lock, you think pulling the meter is safer then pulling the breaker?
amateurs
4" grinder is cleanerIf you couldn't get that off with a sawzall you're not very good at doing bad things![]()
i tryed this once and one of the wire hit the back of the bar that the breaker hooks on whole street went out and probly at least 4 edison trucks were there 10 minutes after that had to eat a little crow with them but at least they let me finnish changing the breakerTo be honest, when my main shit the bed at the river, I figured the Mohave Electric people were going to take forever and charge a bunch. So, I treated those wires like plutonium, loosened the sets and gently wiggled the thing loose...while sweating like a pig, both scared and 110 degrees. Put the new one in the same way.
ring is hardened steelIf you couldn't get that off with a sawzall you're not very good at doing bad things![]()
No it isn'tring is hardened steel
Drilling the barrel is a pain in the ass it has a spring and ball bearing inside of it, when you drill it makes the release mechanism that much harder to get apart.Agreed. But a sawzall would still work. And so would a torch. Heck you could even drill out the lock. Where there's a will there's a way.
Bird on a wire....Done.
You know where I live. Come on over!
