Hey Sparkles - Part II
oldman
The actual ring is cheap ass steel. It has a stainless ball bearing inside the barrel. Attacking the barrel just causes you more trouble.
oldman
All the ones they install here are stainless🤷‍♂️
If they are gold they are carbon steel
If they are silver they are stainless
Both made by Inner-Tite Edison has used both, but your right lately they have primarily gone to Stainless.
i tryed this once and one of the wire hit the back of the bar that the breaker hooks on whole street went out and probly at least 4 edison trucks were there 10 minutes after that had to eat a little crow with them but at least they let me finnish changing the breaker
I did good on that side, I was scared shitless I was going to screw up everything for the neighborhood. I can tell you insulated gloves probably would have been a good idea though. Kids and wife were heading out, and I'd spent the night on the boat...it was F'n miserable in the place.
MPHSystems
Hallett 240
sawzall wont cut it. torch will melt the plastic meter a piece of sheet metal by the meter and grinder small cuts only way
I cut 16 meter rings on 1 job. HOA near the beach, sprinkler peds had rusted away and were falling over. PG&E said their tech was afraid to walk in the bushes couldn’t find them. I just cut them and used the seal rings that came with the new peds. I never heard nothing about it.
Melloyellovector
I mean in litterally every way pulling the meter is safer than changing a 200 or 400amp main breaker live that’s bolted down with 2/0+ aluminum conductors fed into it lol.
mehhhh older home likely 100amp, like playing real life operation easy peasy :cool:
or if Edison taking to long, throw an old screw driver across contacts and short the entire neighborhood out, they’ll get there pretty quick. Lol
MPHSystems
Hallett 240
If you couldn't get that off with a sawzall you're not very good at doing bad things🤷‍♂️
I’ve worn out at least 6 sawzalls in my career. Sawzall is the wrong tool for the job. The ring slides around the meter socket. Sawzalls jump.
if all I had was a sawzall to cut a meter ring, I would drive to Home Depot and buy an angle grinder. I’m not going to scratch up someone’s service or break a meter because I didn’t have the correct tool with me.
JUSTWANNARACE
I will not let them take me🤣🤣
They, the three that i mentioned, are all the wrong tool for the job. But they will all get you in. If you are wanting to use the correct tool you would need the key🤦‍♂️🤣
JUSTWANNARACE
A sawzall right about where the red line is will pop the ring.
MPHSystems
Hallett 240
Have you ever even used a sawzall? A cutoff wheel is absolutely the correct tool for cutting that metal ring. How, exactly, do you plan on getting the sawzall blade on the ring? FYI, an actual sawzall has an orbital stroke, how are you going to keep the tip from bouncing off the material?
Could I cut a meter rings with a sawzall? Absolutely 100%.
Would I cut a meter ring with a sawzall? No fucking way.
JUSTWANNARACE
No I have never used a sawzall. Educate me PLEASE master!!🤣🤣
JUSTWANNARACE
Nice red line. I'd start with turning the blade around genius🤦‍♂️
Its a Sawz-all, not a Sawz-some.
Just remove the foot and flip the blade or use a longer blade or whatever.
MPHSystems
Hallett 240
Tell me you don’t know how to use a sawzall without saying: “I don’t know how to use a sawzall”
The first time I catch you removing a safety feature from a power tool to do something stupid you get sent home for the day. 2nd time you get terminated for cause.
MPHSystems
Hallett 240
So the blade orbits on the down stroke? SMFH You still won’t get all the way the through the lock before bottoming out the saw and damaging the crap out of their stucco and the service high likelihood of damaging the meter. I will say this, I am impressed with your commitment to stupidity.
JUSTWANNARACE
I am impressed at your lack of ability to use a sawzall. Should I just bow to you now? Lol
And if you belive all sawzalls are "orbital" then I'm impressed at your lack of knowledge of the tool! If so you are buying cheap shit🤪
MPHSystems
Hallett 240
If you've used a sawsall over many years, you can practically do surgery with it.. Not sure why I'm still reading this thread..:rolleyes:
Just because you can doesn’t mean you should. Generally sawzall is for cutting rough building materials and seldom is it for finish materials. It is designed for fast rough cuts. I don’t know if you have ever cut one of these locking rings but they slide around the collar. You would need some way of securing the ring to the service to keep it from moving. Without the shoe engage, it’s pure mussel to keep the blade from pulling the saw toward the service or stucco on the up stroke and bouncing off. I can plunge cut into CDX with ease and probably could get the ring off with a sawzall. But I wouldn’t.
oldman
If the only cutting tool you have in your garage is a Sawzall you don't have much of a garage.
If your on a jobsite and that's all you brought.
Then use it.
Grinder is the preferred tool.
But some guys work harder than smarter.
Tweakers?
It’s on a horse property pretty far from the street. I only found it because the excavator installing drains hit a different line in the same cabinet.
All the guys who work the property say “it’s been like that for a long time” lol.
Gotta go find the other end of it sometime today 🤣
oldman
I should be more clear, If any of the breakers were burnt, and compromised the buss in any way, that buss will smoke the new breakers you installed in that location, Usually if the buss has pits, move to a new vacant location.
oldman
Dude...
Scotch-Brite and dialectic grease for the win.
Did I mention that I had a friend who's a lineman? 😁
dielectric grease is not conductive; it is an electrical insulator designed to protect connections from moisture and corrosion. It should be applied to the outside of electrical connections, not between them, to ensure good conductivity.
Isn't that the whole point, to keep this from happening again? No corrosion, no issues.
Like I said, this will definitely last longer than me.
You should have used conductive grease.
your Lineman friend should know better 👍
40 years experience.
He wasn't here when I replaced em all.
The 100amp one went in dry, and it's staying that way! 😁
The bussbars/breaker connection can begin to fail from corrosion or from arcing between the two devices (typically a melted breaker or worn out forks). Non conductive grease in theory inhibits the connection between the two.
We can now argue the legitimacy of that over the next 4 hours.
Side note on my journey today I made a friend. Now on the search for the junction box between Captain Ron’s excavating and this transformer. H1,H2,H3 to each other all have zero volts. Individually to ground I’m at 285.
Dude...
Dieelectric grease or Nolox that is or was typically used for aluminum connections ? Nolox is what's commonly used and is conductive and protective.
Seriously you should be fine. I'm horrible about worst case scenarios
Back when cars had plug wires...
The manufacturer Required DG in both end of the wires, for all the obvious reasons.
Never saw any issues steming from that, so I made an executive decision to put a touch at the buss bar connections.
I'm pretty sure I'll be fine.
oldman
I'm pretty I'll be fine.
The call for DG was to seal the boot to the plug or cap for water intrusion under the hood, We use DG in under ground components as a sealant not for conductivity. All of The conductive lugs are filled with a gritty NOLOX type grease, same with overhead conductors. The utility also buys wheel bearing grease in 5 gallon buckets, the guys carry in little jars with a brush.
Scotchbrite and a new breaker should last you a long time.
Post that shit on MikeHolt.com and that could generate 50 pages of sparkys expounding on why mechanics should stay in their own lane. 🤣
Now you've got an ole lineman schooling yo-ass, so my job here is done. 😉 Next time use Nolox, that's what it's made for as it serves both purposes --- but DO NOT use it on spark plug boots because where it goes, so does electricity.
I'm pretty sure you'll be fine too. 🥴
It's definitely two different worlds.
I know enough to get myself in trouble when it comes to AC. But I'm also not afraid to ask (Stoopid) questions.
If you think us RDP boaters argue, step into the Wide World of Sparky forums, which makes various religious faiths and denominations arguing over holy manuscripts seem like a big kumbaya love festival. 🥴 😉
