7.3L guru's please help
Mototrig
Long story short I need to replace the central junction box (fuse block) under the steering column in my 2002. Who knows how to decifer the part number on it to check compatibility online?
I've found quite a few fuse blocks on eBay with similar but not exact part numbers.
So far I've been unsuccessful and finding a close match reman.
Below is my part. The closest match I have found has the underlined different, everything else being the same.
Joker
@rivermobster
I think he owns one of those turds😁
SBMech
Fixes Broken Stuff
That's not the part number .... the part number in that pic is 2C7T-14A067-AN.
Here's one on fleabay : https://www.ebay.com/p/1424678394
There might be supercessions if it's a new/updated model, I would go with a reman one myself, fixed the problem in them...you hope.. 😜
Mototrig
Why do you have to Replace the whole fuse box? 🤷‍♂️
Water came in from a leaky windshield. Both sides of this connection melted beyond repair.
That's good to know, thank you for the clarification 🍻 I'll reach out to this seller!!!
Mototrig
How many wires are in that connector? Maybe just by-pass it?
I swapped a new connector from a doner truck, I believe it was 11 wires total.
I used one form a fleabay vendor like you recommended, a seller out of Van Nuys for anyone who needs a recommendation. For $300 we're back on the road again
