Nordie
- Sep 5, 2009
- 8,069
- 12,923
Recently purchased a boat and the reverse isn't happy. I went through and adjusted the lower cable to spec. Anytime I put it in reverse (in the driveway not running) as I travel it throws the interrupt into kill the engine. I can't even get to throttle in reverse. On the water it's the same result, I can click it into reverse at idle and maneuver around, but if I go to throttle up the (I'm gonna call it a switch) breaks the ignition circuit. What am I missing?
The problem seems simple and something seems out of adjustment.
Obviously forward is completely fine, just reverse, what do you guys think I should do? Do I need a new cable, or is it really something simple?
