Bennett trim tabs
MPHSystems
Hallett 240
What to do with Bennett trim tabs? I’ve been told there are no parts available. I’m pretty sure the rams work but the indicators are screwed, the box was taken out and it probably doesn’t work. How do I make this right?
Shlbyntro
Ultra Conservative
old style independant indicators are obsolete and NA. my indicators are built into my control pad you will likely have to update the controller and signal box to the new style
all other components are still readily available
MPHSystems
Hallett 240
The pump reservoir is being held together with zip ties to the pump. Can I just use the new indicator switch combo? Can I buy a new pump?
Shlbyntro
Ultra Conservative
yes, you can buy a new pump. pumps are still drop in replacement and have not changed. The link aloha Jeff shared is the new style controller with the built in indicators. it will require a small box mounted near the pump with a small wire harness run forward to the new controller. you can also upgrade to Auto-up functions and fully automatic functions
