Bpracing1127
- May 31, 2012
- 10,905
- 14,456
Figured I’ll start a thread on my summer project for my rzr turbo s4
I now have 4700 miles on the machine and after a 2300 mile season it’s time for preventative maintenance more than just oils and filters
One big difference project is getting my turbo rebuilt with new bearings and seals. I will also be putting a new compressor wheel on ( billet) too for a little more HP. This is a fairly major project due to the workable space and that exhaust bolts tend to break on these.
On my peace trail ride I blew a belt and it blew a hole in my inner clutch cover so that needs to be replaced. I also noticed it was rubbing on the drive shaft output from the tansmission too.
Once I got the clutches off I notice I have a small oil leak from the seal on the trans input shaft. I’ll get that replaced so it doesn’t leak more oil into the clutch housing.
Looking at my clutches my primary is showing a little sign of roller wear but nothing crazy. I am on the fence if I am going to run it or buy a new primary. I will be replacing all the wearable sliders in the primary and secondary as well.
After all of that I will have my front/rear shocks rebuilt with new seals. Rears need a slight valving change at near full bump (too soft) mid stroke is good tho And rebound seems good.
Moving onto the front of the car. I will be replacing the rack after scoring a deal on a bran new shock therapy billet race rack. More on that later.
Also modified my harbor freight Jack for the pro eagle extension ( I should have done this a long time ago)
