EmpirE231
- Jan 10, 2008
- 5,029
- 10,572
So I am in the process of building a safe "closet" in my garage. Trying to make it as fire resistant / burglar resistant / insulted as possible.... but on a semi budget.
I am planning on still using wood framing / 2x4 construction walls. Has anyone used the fire resistant paint? does it actually work? Considering painting all the framing with this.
Planning on using the fire resistant insulation, such as this...
Is this good insulation, or is there something better in that price range?
The plan is to wrap the framing in some thick 1" plywood, and then use the fire resistant drywall over it, unless someone has some better suggestions that doesn't require some crazy construction skills.
temperature.... if I want this closet to have better temperature than the rest of my garage, should it be ventilated, or closed off? I'd like it to stay much cooler in there for food storage.
Owens Corning 15 in. x 47 in. Thermafiber Fire and Sound Guard Unfaced Mineral Wool Insulation Batt SG-25-P3--15--47--221 - The Home Depot
Give authentic fire protection to your home with the help of this excellent Owens Corning Thermafiber Fire and Sound Guard Unfaced Mineral Wool Insulation Batt.
www.homedepot.com
