Carb Identification help?
wet hull
Does anyone know what kinda carb this is? I need to order a rebuild kit as its leaking fuel from this spring circled in red and dripping onto manifold. I cant find a part number on it anywhere.
mjc
Retired Neighbor
There are no gaskets in that part of the carb so it may not help since shaft is probably worn-out
wet hull
Any ideas for a fix there besides new carb?
Shlbyntro
Ultra Conservative
drill it out and press in a brass/bronze bushing.
those areas tend to wheep a tiny bit. when fuel is running out of them your carburetor is generally flooding in addition to a worn throttle shaft
mjc
Retired Neighbor
Probably cost more than a new carb. I might have a body unless I tossed it out. The biggest problem I had with mine was accelerate pumps drying out when car was parked awhile from crappy gas.
