Ace in the Hole
- Aug 15, 2020
- 6,342
- 15,036
Looking at doing the following on my 2020 since the fuel pump recall has now been completed. Swaps the rear and front fuel filters to spin on cat filters (better filtration, easier to service, etc). If I do it I plan to add the heaters as well since we go where it gets pretty cold. Has anyone done these? I'm over the PITA filters that are on the new trucks..
blackmarketperformance.com
BMP 6.7 Cummins Rear Cat Water Filter Adapter 13-24
BMP Rear Water Separator Cat Adapter for your 13-18 or 19+ Cummins, This replaces the Rear Fuel/Water Filter Housing and stays in the factory location using factory quick connects, no cutting or adding fuel line 100% plug and play! This works in line with our front mounted Cat Adapter and will...
BMP 6.7/5.9 Cummins Front Cat Fuel filter adapter 03-24
REAR KIT IS NOW ALSO AVAILABLE FOR 19+ 6.7 CUMMINS TRUCKS, PROTECT YOUR CP4 WITH A FULL SYSTEM! Kits for all 6.7 Ram trucks years 2003-2024 Finally a solution that replaces the problematic factory fuel filter housing that has a plastic cap known to seize and break. The BMP 6.7 Cat Fuel filter...
BMP Front 03-24 Cummins Spin on Fuel Heater
Now Shipping Add a Fuel Heater to your 03-18 & 19-24 Cummins Front Cat Fuel Filter System. If you live in a cold enough environment for fuel to Gell this kit is a must. Built in thermostat Spin on Design Uses factory harness Prevents fuel from gelling
BMP Rear 13-23 Cummins Spin on Fuel Heater
Now Shipping Add a Fuel Heater to your 13-18 or 19+ Cummins Rear Cat Fuel Filter System. If you live in a cold enough environment for fuel to Gell this kit is a must. Built in thermostat Spin on Design Uses factory harness Prevents fuel from gelling
