- Jan 11, 2010
- 14,571
- 38,497
Today’s project was to shorten some brembo caliper pistons to 26mm in length. I had 36mm and 42mm pistons to do, 20 each.
Normally for one or 2 I creep on it, shut down, measure, make another cut, confirm, etc…no time for that on 40.
I could make some 5C emergency collets, but then I’ve gotta yank the chuck and find the collet stuff…nope.
I saw a chunk of aluminum I fucked up last week when I was hired to make a 33mm turbo restrictor for a rally team (napkin sketch didn’t match sample…I referenced off the sample)…so I cut that up and made a few “fixtures”
Wall thickness I was hoping would be thin enough where I didn’t have to make slits. Concentricity doesn’t matter since I’m only working on length. It worked! Chuck jaws collapsed the adapter things enough to grab the pistons and relaxed enough to release them.
Made one for each size piston with a step to stop on the chuck jaws and step to stop the piston. Set up an indicator on the carriage and knocked out all of ‘em in 15 minutes. $10 each. Not bad.
