Filing down a skeg?
pkrrvr619
So in a previous post I mentioned i hit a rock and did some minor skeg damage. It is not going to affect performance as it is very minor damage but it still bothers me.
Does anyone have a link on how to file down and smooth out the skeg? I tried the search but could not find anything.
Would like to get this thing filed and painted before next weekend.
Thanks!
Link?
File it until you've removed the damage and the rework is mostly uniform side to side, then paint. What's your specific question?
pkrrvr619
Link?
i suppose i am wondering if using a power grinder is the way to go or a hand file instead. Since the skeg is aluminum, i don't want to butcher the thing and make more of a mess for myself.
if a power grinder is the way to go, what grit on the disc is needed?
I don't want to fuck my out drive up so any insight would be greatly appreciated.
both accomplish the same task, all depends how hard you want to work. Post a picture of the damage
spectras only
You should have a welder with knowledge of welding aluminum, adding material and finish it off like the original shape.Like a trailing edge and tips of airfoils, it should always be sharp, not round;)
You need to weld a piece on then grind and smooth.
spectras only
^^^:thumbsup
the skeg needs the point to have minimal disturbance/drag under way. It doesn't need to be razor sharp, 0.5% blunt edge will have minimal drag.
240Hallett
^^^:thumbsup
Does all this really matter on a 60 mph boat?
rrrr
Nope. Just contour the corners and remove material on the bottom edge so the repair area is blended.
Don't do this. The bottom edge should be radiused, not squared off or sharp. You don't want to have a safety hazard.
I prefer my skeg hit instead of my prop. But yes you can grind of as much of it as you want and performance will not be affected.
pkrrvr619
Thanks guys.
This is very minimal damage, its more like the skeg is rough and needs a touch up, not surgery. So i think a hand file and quick grinder may do the job.
Appreciate the insight.
nowski
Thanks guys.
I'd consider using a sanding block with maybe 100 grit emery cloth...
