TPC
Wrenching Dad
- Sep 20, 2007
- 32,892
- 28,503
Our front hydraulic jacks decided to stall and/or retract on their own. This can be treacherous if you're trying to hook up the truck and they decide to lower before the pin is connected to the hitch. Also you're camped and suddenly the front of the RV is 18" lower than the back because the jacks retracted on their own.
Also you're unhitched and laying in bed and every few minutes you hear a repeated POP from the front jacks. Especially in warm dry climates.
The jacks are sticking and at the valve seat.
You'll need 1 quart Cat Hydraulic oil additive or MC shock oil.
Draw a quart of hydraulic fluid out of the RV reservoir and replace with the quart of additive or shock oil:
Bring slide outs in and rear & mid jacks up.
Then:
1. In my case I opened the passenger side propane cabinet then top of Jack turn Allen nut on top fully closed. - That’s counter clockwise.
Exercise front jacks.
Step 2. If that doesn’t do it open the Allen screw clock wise and exercise jacks, then close counter-clockwise.
Step 2 did the trick in my case It worked. Stopped the popping and the jack are not failing - working only on command.
If you don't have the additive try it with out it and you may have good results anyway.
If none of the above works, (and remember it may take some time for the lube to circulate through the system) replace valve.
I will order a valve to keep on hand.
Then:
