TPC
Wrenching Dad
- Sep 20, 2007
- 32,915
- 28,553
The 9500 lacks a 50 AMP receptacle.
Video gets informative at 2:30:
The Only inverter generator I could find was the PowerhorseDo any of the generators the same size have a 50 amp receptacle? I know they have 30 amp.
Is it just assumed or always the case, that if it has a 50 amp plug it is split phase 240v or can you have a 50 amp plug that is just a 50 amp single phase?
The one I posted above, zoom in on the pic and the 50A receptical says 120/240 [emoji106]
I have been watching some pretty interesting youtube videos of different ways guys wire up 50 amp RV services.. or if there was such a thing as parallel output on a single phase , so I thought I would just ask...
The 240V generators that you are referring to are single phase (sometimes referred to as split phase). They have two hot legs that are 180 degrees out of phase with each other but because they are exactly 180 degrees out of phase (perfect opposites) they are referred to as single phase. There is also a neutral that you can use along with one of the hot legs to get 120V. I do not know of any generator that produces 120V @ 50A and splits the 50A between the two hot legs on a 4 prong plug. That could actually be pretty dangerous if someone didnt know it was a non-standard configuration and I don't think any company would ever build a generator like that.Is it just assumed or always the case, that if it has a 50 amp plug it is split phase 240v or can you have a 50 amp plug that is just a 50 amp single phase?
Multi phase (like 3 phase 208V) is an entirely different animal.
Good description.Most RVs that use 50A service do use a 240V plug but don't have any 120V appliances. Just like your house, they have a panel that has 2 separate 120V sides. Since there aren't any 240V appliances in the RV, it is safe to tie both of the 120V sides together and feed them together from one 120V source. A pigtail adapter like this ties both hot legs together in the adapter.
