Hatch options
Husqy510
We are in the process of rigging this 26 Howard and the motor is a little too tall. Now we're trying to decide which route to go. Any feedback or photos of what you did would be greatly appreciated.
Option 1 is to cut a round hole so the flame arrestor sticks through.
Option 2 is a fiberglass pro-stock style scoop.
Option 3 is build a raised section on the hatch. This is probably my favorite options, but I'm worried we won't be able to find the vinyl.
Shrub Lurker
Sweet Bote'. Can you go back to a one barrel carb. That hatch and interior look amazing . I understand your delemma ....
Guest06
Yea, so what if you lost a few hp what about a little shorter manifold and no spacer.
Husqy510
A lot of money went into building and dyno tuning this combo, so I'm not crazy about changing anything. The spacer is actually a 4150 to 4500 adapter so I can run the dominator, however they do make one that is less than an inch thick that I'm going to buy.
Of your three choices I’d say scoop
3queens
Detachable Member
just cut a hole and tuck
install something like this or OG style similar but a cover made of wood attached to your hatch
Nice motor BTW :cool:
CoolCruzin
Hard to tell which would look better with out seeing the boat
ltzcrew
do a small bubble one. mine has it and its not bad. have to watch where you step when its wet or it acts like a slide haha ill post pics of mine tonight
BUSTI
Dump that manifold and spacer. Get a manifold that's made for the Dominator. It will be nicer in the end.
ltzcrew
here's mine, hides the motor well and gives it some nice space , its open in the rear center to the swim plat forum witha slot maybe 3 inches all and 10 wide to make sure the motor can breath
