Horrible Fab job I need fixed
28Eliminator
I designed this “improved” umbrella mount for my boat swimstep. The guys I agreed to have put it all together… well, see for yourself 🤬😩
  • Platform mount-2.pdf
28Eliminator
Throw it away start over 😁
I got another piece of tube. I’m gonna cut the hack job tube off and start over. Need someone that can TIG weld the tube on CORRECTLY.
All stainless.
Icky
I can do it, but not after all these guys practice on it 🤣
bilz
Newly Retired!😁
Bondo and krylon are your bestie at this point!
rlemn8r
Let's go to the river..
You are in La Quinta correct?? I know a guy in Palm Springs that can help you if you are interested.
Bajastu
From the looks of it they tried to tig weld but someone doesn’t know how to back purge or weld stainless steel. Or it was cheap China stainless, that stuff is such poor quality. The good stainless is getting pricey.
joecfd1
From the looks of it, I bet they had Stevie Wonder as the torch!
28Eliminator
Yep. I’m leaving for Havasu on Friday for a week. I’ll get ahold of you when I get back.
Thanks!
ltbaney1
Stainless is a PITA to work with, takes some skill/experience. We built a stainless umbrella holder for someone's floating hangout bar in Havasu recently. Patent pending!
These inflatables from Bote are pretty darn cool.
View attachment 1428314 View attachment 1428315 View attachment 1428316 View attachment 1428317
thats the truth. ill weld the hell out of some aluminum, but i struggle a bit with SS. ive been told i try to run it to hot / fast and over cook it and burn the nickel out. a few beads here and there im ok, but all day i struggle.
View attachment 1424044 View attachment 1424045 View attachment 1424046 I designed this “improved” umbrella mount for my boat swimstep. The guys I agreed to have put it all together… well, see for yourself 🤬😩
Just saw this (for some reason)....
You may be a step ahead of me on this, but a good tip for using that style of lock bolt / retaining bolt, without garfing up the thing you're clamping in the tube....centerdrill the bolts about 3/8" deep and smash in a piece of weedwacker string....biggest you can fit in whatever bolt you're using. Leave 1/4" or so hanging out of the tip of the bolt, and that'll sorta smash up in the hole against the thing you're clamping and create a nylon tipped bolt and hold it in place nicely without so much as damaging the paint most times.
