Tahoe540
- Aug 2, 2016
- 356
- 477
Will these fins hurt top speed or performance? I have not seen them on any other loaders. This is on a Hallett day cruiser.
Thanks for the input on this. It is my first jet boat and learning as I go while upgrading this boat. I have had the jet totally rebuilt with all the goodies (stainless bowl stuffer, A impeller and droop) while the stock 454 was still in the boat. Obviously have not got to the intake. I have read that a basic rock grate is not very performance minded.
You guys have any suggestions on who to talk to about a new loader?
I installed a pretty healthy 555 BBC and it just doesn't have the rpm or speed I was expecting. It will only do a few mph better and the same RPM as the stock 454 it had. It hits a wall at 4800 rpm (same as stock 454) and I am trying to figure things out. I have pulled the motor numerous times checking cam timing, bearings, etc. I did do a compression check and the cylinders are only within 3 lbs between the highest and lowest readings.
Good to see some jet boat activity! As mentioned those fins are on all of our jets. Stock rock grate is a good idea for obvious reasons, suck a rock and you'll need a tow in. I personally run my 21' cruiser open, although I'm always very aware of the water depth and bottom conditions. Until you match up your impeller to your engine you won't see much gain. Loaders rarely have a gain that you can feel in the drivers seat unless your really performance minded in your setup, I have a 19' Daytona so yea I can feel that stuff. Not sure where you're located, I like Chris & his guys at B1 Racing. Tom with JBP is on this site quite often, I've talked to and purchased parts from him in the past.
We would need much more detail about your engine & jet to advise. Going with a B impeller will get you more rpm's, will that translate to more speed, maybe, maybe not. Will be quicker. Then again AA impeller could be a possibility too. View attachment 919020 View attachment 919021
This View attachment 919023
was in mine when I bought it. The thing about loaders is if they break it will be the most violent feeling you'll ever experience in a jet boat, passengers can get hurt to when the boat makes a sudden stop sideways.
One more piece of information. It currently has 3/8 line from the tank to carb. I am going to do a test this weekend with an electric pump and 1/2 line and -8 fittings.
It looks fast you think it would be fast LOL View attachment 919051
Curious as to how well it breathes with 555 ci. through log style manifolds?
I don’t know if running without a grate or loader just an open hole is good but what the hell give it a try
On the regulator 180 psi seems high but volume of water getting into the logs could cause back pressure.
I think 180 psi is full pump pressure
Regarding the gauge on the intake manifold it should show vacuum at idle and I don’t think it will ever show pressure
I have heard of running a pressure gauge on the jet pump and a gauge on the exhaust/ engine side of water inlet
I believe those are referred to as bacon strips or meat curtains. Some boats have them, some don't.Will these fins hurt top speed or performance? I have not seen them on any other loaders. This is on a Hallett day cruiser. View attachment 918957 View attachment 918958
So I looked at jet boat performance website and found the information I was talking about try this link
Jet Boat Performance, Jet Boat FAQs diagrams, Impeller charts,
jet boat references, charts, jet drive parts, breakdowns, plumbing diagrams, jet boat header plumbing, jet drive wet logs plumbing,Jetboat impeller charts, electrical wiring diagrams, jet boat information, jet boatjetboatperformance.biz
On the HP to RPM chart it only takes 375 HP to turn an A impeller at 4900 RPM once you figure out the problem your going to be a happy boater
