Cray Paper
- Jul 28, 2012
- 4,160
- 4,611
When I bought my boat it had 3 Optima Blue Tops in it and I thought no matter what I wouldn't have battery issues. Every time the boat was parked at home I put Battery Tenders on the batteries and thought it should be no problem to get them to recharge. I think they were low on charge when I picked the boat up but worked. Last spring I decided to replace the 3 with 2 new Blue Tops as they didn't seem to hold a charge very well and were 13 years old. We got careless last year and for several reasons the tenders were not plugged in, or were plugged in later after the batteries had discharged.
The last time I used the boat last year one of the batteries was dead so I pulled one out of our travel trailer and it did fine, swapped it out before putting the boat to sleep for winter and put the trickle charger tender on it. At some point during the spring the cord was unplugged so neither battery was being charged. So I now just catching up on this and now understand the issues with trying to recharge dead AGM batteries. I had to bad a new blue top to get the hatch open and start the engine to de winterize. Now I am trying to resurrect the 2 dead 1 year old blue tops. I am using my dads Snap On charger, connected one the dead batteries to the battery in my work truck with jumper cables and hooked the charger to the dead blue top. The blue top had 2.5V when I started, after 1.8 hours it was up to 10.8 volts. I hooked another AGM specific charger to the 1st dead blue top and unhooked the jumpers from the good battery.
I then hooked up the other dead Blue Top (8.9V status) and connected the jumper cable to good truck battery and Snap On charger to dead Blue Top terminals.
Anyone else done this before? Taking a severely discharged AGM and charging it back to normal? I've seen some people say to draw the undercharged AGM back down to nothing and start over and keep repeating until it reaches 12.6V. What is the easiest way of drawing the battery down? I dont have many things that clip on to a battery other than portable air compressors, will that work?
