OCMerrill
All in...
- Sep 24, 2007
- 27,509
- 11,680
I need to diagnose a rough idle or stumble at idle. Either in gear or out of gear. Its clearly missfire.
Had all the injectors rebuilt and installed them. Now I come to find out I'm under propped (straight past 5k) so that result was great.
Now if I could cure the rough idle stumble. Had it since I bought the boat 4 years ago now. Getting worse hence the rebuilding of the injectors. No change.
Its likely an electrical issue or the ECU thinks the engine is cold and needs to stay with a rich mixture?
Also when I took the upper plenum off there was some oil in there. Perhaps thats normal for 817 hrs. I know the intake arrester was filthy and thats now clean. Some of the tubes leading from the plenum were clogged with coaked oil and are now clean.
This is not something I want to just throw parts at although the Intake setup I purchased from @Maw has a mini parts wherehouse attached so I could swap stuff around.
I would rather look for codes or see if some enrichment table is being deployed.
I would like to own both however I am having a hard time figuring out the actual Merc Manual(s) as I see there is maybe a part one and two?
Best place to purchase and what manual number?
Also looking for a scan tool that will work with my year?
Engine serial number OK151969
All this is clean now, during re-assembly.
