I have not check on Marine gear for an LS but would assume its pricey and not as easy to pick up...
That’s just a factory setup with the LSA tho, not a custom build.probably a good question for tahiti boats since they have equipped several of their builds with ls based engines both with outdrive and jets.
Just curious are guys out there running LS engines and getting good performance out of them ? Seems like you can get a lot of power out of an LS pretty cheap. Or is there a reason why big blocks are just industry standard ?
True. I can’t remember if it was them or someone else that picked up a ls454 from Kodac. I think that might be a decent barometer as to how these ls engines handle the constant dutyThat’s just a factory setup with the LSA tho, not a custom build.
I’ve spoken in great detail with the builder for my offroad car engine and he says cast block 408/416” depending on the block and small turbos would be a perfect swap and make a very conservative 700-750hp with the same or better tq curve. Than you start at Hardin Marine with all the accessories etc and realize its all there and just awaiting someone to do it and wake up the masses.
HP is one thing, torque is another.
I can't imagine a an LS would push a jet very well.
But, if you came up with some interesting gearing and propage (I just made that word up!), maybe an LS could work?
A deep pocket book would be required for testing I'm thinking...
Properly built you’ll see an LS-X build makes insane tq. 440” with a 4.5L which now you’re talking $$$ will make a solid 1200hp and 980-1050tq and still make a tq curve that starts getting after it in the low 2000rpm range but doesn’t drop off till into the 5000’s yet spin 6800-7100rpm all day long.
Not me...... and i did say you’d be talking $$$$$$ but A: it’s going to be lighter and B: it’d be cool and different.How much did you say that cost you exactly?
418” 750hp/725tq10-4. You have a link to this build? That's a lot of torque from a small displacement engine!
418” 750hp/725tq
CBM MOTORSPORTS™ SUPERCHARGED 425 MARINE LS3
The CBM Supercharged 425 Marine LS is a 6.95 liter Whipple supercharged is a 6.95 liter supercharged LS3, it puts out 750+ hp @ 6800 RPM's and 725 ft-lbs of torque with a compression ratio of 9.1. Features pair of CBM custom built CNC ported L92 cylinder heads, a forged lower end.store.custombuiltmotors.com
454” 900hp 875tq
CBM MOTORSPORTS™ SUPERCHARGED 454 RHS LS
The CBM Supercharged 454 RHS LS is a 7.4 liter Whipple supercharged LS, it puts out 900+ hp and 875 ft-lbs of torque.store.custombuiltmotors.com
463” 1600hp 1400tq
And this is just CBM there are plenty of others doing similar and bigger platforms. Mike Porter of Redline has moved the LS bar up from there as well.
Well except the one that clearly states 1400tq. The numbers i gave earlier are a 440 a good buddy just built for his sand car. When I’ve spoke with Bruce, he’s told me straight out he could build, or more more correctly Brent could build me more than plenty. Idk what dick sizing contest you’re trying to swing but you asked for a link i posted it. As well there is Danzio, Redline, TSP, Alper, Mast and many others who are all making these same numbers day in day out from an LS. And no one said “LS1” biggest I’ve seen so far myself was 489” from an LS platform and have heard in excess of 500”.Bruce is a friend of mine...
You realize not one of those engines are rated at 1000ft lb of torque, correct?
Everyone is following Finnigan's build, right?
Mid 70's. But I'm not sure what engine it is?
418” 750hp/725tq
454” 900hp 875tq
463” 1600hp 1400tq
Why do a single, I’d do small twins. And sure you can intercooler anything. Idk the op asked about it, and i did a ton of homework when planning to do my last boat. Things changed when we bought our new to us boat but it’s still completely do able, and about 13k for everything other than the long block.Sure it could, but who has done an LS turbo with a closed hatch outdrive boat ?
The single turbo LA manifold alone from hardin is 4K alone and you still have to buy the other side.
Whipple just showed up. View attachment 1026491
I will just drop this here. And this was 8+ years ago.That’s neat that people are making bigger hp with ls motors with forged induction but you aren’t seeing as much hp from a NA LSx as you will a bbc
I mean it’s pretty easy to build a 600-700 hp large cube bbc like the 548s in my cig as a pump gas engine. Try doing that with an LSx
Bbc is still the king of big power after the hemi headed nitromethane motors.
look at a billet proline motor making 4500 hp
If someone was trying to save weight, a LS set up would be best with the all aluminum block/heads?.
In a jet boat? I don't think the weight savings would over come the lack of torque. Dollar per dollar or course.
Now in a air entrapment hull? Their could be come validity to this theory.
That LS in the jet bote Finnigan built on his channel seems to overcome the lack of torque. 77 MPH out of a 384 CI stroker LS with heads, cam and a tunnel ram.
Wait just a second here...
Just like an F150 can tow pretty much anything, Every jet boat can go 90mph!
77? Pfft. Big wow.
But all kidding aside...,..
He's dumped a shit ton of money in that project. If you put that same amount of money in a BBC, that project of his would be eating the BBC's roost.
The point of this thread was cheap power. Sadly, that's not gonna happen with an LS.
Have you seen craigslist? Every jetboat goes 90.
This speed range is a great area to have the discussion though, because you don't need anything exotic on the LS or the BBC side to do 75-80 MPH in a jet boat.
Agree you are gonna get more power per dollar out of a big block. but its gonna cost cubic dollars to pull out 300 lbs of weight out of the back of a boat. Certainly more than the difference in price between the 2 powerplants. So the question is how much more power do you have to build into the BBC to overcome the weight disadvantage?
Case in point..
I have multiple friends with the exact same boat as me. I have a stroker small block and they all have big blocks with 50 more HP. I'm 250 lbs less weight. Their boats run only like 3 MPH faster than mine best case, and at times its been a dead heat. Pretty close all things considered!
Another interesting experiment - It would be interesting to see what a 500HP LS and a 500 HP BBC could do in the same boat.
Then enters in the 6.7l performance diesel.
