spectras only
- Sep 20, 2007
- 13,532
- 14,043
I am running Bitdefender Internet Security 2015. Windows Defender seems unaware that Bitdefender is present. If I have turned off Windows Defender in the rgistry editor, it turns itself back on.
On waking from sleep, both Antimalware Service Executable and Bitdefender are running, CPU utilization is 100%, and my system freezes for several minutes.
I found the answer on Bitdefender's forum, that you can turn Windows Defender off in the Policy settings:
Suggestion was ?
1.Press the Windows key + R to bring up the Run box. Type gpedit.msc and hit Enter.
2.In the left pane of Local Group Policy Editor, navigate to the following location:
Computer Configuration -> Administrative Templates -> Windows Components -> Windows Defender
3.In the right panel you will see a policy labelled “Turn off Windows Defender“. Double-click on that policy and set it to Enabled.
However, Microsoft doesn't seem to recognize gpedit.com when tyiping it in the run box.
I may try to disable AntiSpy and AntiVirus protection, or delete Windows defender all together in the registry editior?
Any suggestion from the RDP IT gurus? Thanks
Suggestion was ?
