Phoenix area LS rebuild shop needed
DLow
Single Barrel Dweller
Anyone in the Phoenix are have a reliable, knowledgeable shop that can do a basic 6.0 LS based rebuild? Looks like I have a bottom end starting to rattle pretty bad and would like to freshen it up before it gets worse. Mild cam swap and tune while in there. We are talking a 3500 family van, so nothing crazy. Just a dependable rebuild.
DLow
Yes Larry is at the top of the game and I would head to him if I were in Tucson. He just is a little tough logistically for me right now.
530RL
"The Oracle"
If you are going to pull it out yourself and it is just for the family truckster, I would consider buying a short block either new or rebuilt on-line.
It might end up being a lot cheaper than going to a builder and there are a lot of quality products out there for your purpose.
28skater
Turn Key Engine 886001LB LS2 6.0L 470 HP Turn Key Long Block Assembly
  • Price:
    $6,350.00
    SKU:
    886001LB
    Brand:
    Turn Key Powertrain
    Weight:
    550.00 LBS
    Shipping:
    Calculated at checkout
    Quantity:
    *Image is a representation of this item. Actual item may vary.
    Specs
    Cubic Inch / LTR's:
    364 / 6.0
    Horsepower:
    470
    Ft. Lbs. Torque:
    450
    Compression:
    10.9:1
    Aspiration:
    Normal
    Rev Limit RPM:
    6800
    Block:
    Cast Aluminum
    Bore x Stroke:
    4.00" x 3.62"
    Crankshaft:
    Nodular Iron
    Rods:
    Forged Powdered Metal
    Pistons:
    Mahle Forged
    Heads:
    Cast Aluminum
    Chamber CC:
    64.5cc
    Intake Port CC:
    210cc
    Intake Port Style:
    Cathedral
    CNC Ported (Y/N):
    No
    Intake Valves:
    2.00"
    Exhaust Valves:
    1.55"
    Valve Springs:
    GM Beehive
    Retainers:
    Steel
    Rockers:
    1.7:1
    Pushrods:
    5/16" x 7.400"
    Lifters:
    Delphi Hydraulic Roller
    Camshaft:
    Hydraulic Roller
    Timing Chain Set:
    Single HD Roller
    Product Description
    Features of New TK Long Blocks
    • New GM OEM Oil Pan
    • Harmonic Balancer
    • Front and Rear Engine Covers with Seals
    • Top Engine Valley Cover
DLow
Yes. I have been looking into this as well. I’m just not sure I have the time right now, but this may end up being what I do.
BONER
Tim @ 1320 Industries
or
Clay Forrester @ FRE Engines
