Bowtiepower00
- Apr 20, 2015
- 2,573
- 4,168
Now that I finally have around 600 miles on it, and have taken it to Glamis, I thought I’d start a thread about my Turbo R 4.
I picked the car up the weekend of SSSS here in PHX at Ridenow Goodyear. With a $5000 discount, I was right at 40 OTD. I was able to use online sand show discounts to order all of the parts and accessories I wanted, including Paddles and Beadlocks.
My goal was to build a capable and well equipped car, without burning too much money on things like cages, seats, etc, that are nice to have, but not “must-haves” IMO.
Some of the things I’ve added:
PCI radio/comms
Rugged pumper with adjustable switch and Bell helmets
BD 10” clear bar/ RZR hood mount
TMW front bumper with 4 BD squadron sports (amber)
BD RTL chase bar
5150 whips
Vet nets for the rear to keep my 10YO safe
RC door bags and rear seat bag
Switch-Pros
Polaris rear and side view mirrors
15” take off/ rampage fury spare
33” SS360 paddles on System 3 beadlocks
Decent amount of throwaway tools from HF, so I won’t be heartbroken if they get lost.
I run the spare with a Y- strap in the bed, it fits perfectly without a mount. I don’t run a spare at the dunes, but I threw one of my paddles in the back to see if a 33 will fit- and it will.
The majority of my riding is 30-60 mph desert trails/ rocks in the NW valley. Most of the guys I ride with run canned hams, with some RZRs thrown in- all turbos, a mix of 2 seat and 4 seat.
My impressions:
Car is huge, and is 75-76” wide at ride height. I have to strap the front to get it to fit in my TH, which is 74ish between the cabinet and the wall. A little over 13’ long.
Car is super tall with the factory cage, just over 80” but it clears the rear bunk even when strapped together.
Lots of 3 point turns on tight trails, and on less traveled trails I’m the full width of the trail- or wider in a lot of spots.
Ground clearance is excellent- even on 32s, I easily clear stuff the X3s drag over, my springs have not yet collapsed.
I have the ultimate, with the Fox dynamix shocks. Overall for most riding at sane speeds the car rides well, and loves the whoops. 90% of my riding I stay in baja mode (the stiffest) and the full firm “X” button works well on the big hits.
15-25 mph I can keep it in comfort mode, anything faster and I’m bottoming out. Today was the first ride we took it easy on, and I was able to use comfort mode quite a bit.
Rock mode works well on the few occasions that a wash turns to rock, but in general I don’t go looking for rocks. It’s a little stiffer than comfort mode.
Track mode is fine on the street, and off-road until you start adding speed, above 35-40 mph it starts to bottom in the rougher stuff.
Baja works well until you’re riding hard- if you’re hitting big stuff above 45-50 mph, or in the dunes, you’re going to run out of compression damping.
I typically have 50ish pounds of tools, my spare, and a small soft cooler in the car, and figure 350-400 pounds of passengers. The car doesn’t seem to notice the weight compared to the lighter cars- say a 64” RZR turbo.
In the dunes, I don’t carry a spare, but everything else I listed above. The car does not have enough compression damping and bottoms frequently when running hard.
Frankly, the car needs suspension tuning if you’re going to be running it hard.
Clutch wise, moderate running, not really an issue. When running hard in the desert, I get enough slip to occasionally go into limp mode for a second- but not enough to throw a code. In the dunes on 33’s, I need a better clutch. I did not blow a belt- but there was slip. Keep in mind, the group I was running with at Glamis were all in built/ tuned rigs and run pretty hard. For less aggressive riding, your opinion might vary.
I will likely add an AA clutch kit including helix this summer. Possibly a stage 2 tune.
That brings us to power and fuel economy. This is a heavy car. In the desert, I have plenty of power and rarely use full throttle. In the dunes however, the X3s, even stock, are quite a bit quicker/ faster. Most of the guys I ride with have tuned cars- and they will gap me pretty hard when they get on it. I didn’t have any issues keeping up, until the long straights.
Fuel economy is much worse than the canned hams, I got just under 6 mpg running to duner diner and back, used 11.5 gallons to go 66 miles. This was pretty much WFO running- our group of 8 cars lost 4 belts on the ride- luckily I wasn’t one of them. The other RZRs weren’t any better. We all came back to camp with the low fuel light on, while the X3s have 1/8-1/4 tank left.
I have read the Pro uses even more fuel than the Turbo, but I haven’t rode with one yet to compare. My typical ride from my house on desert trails is 40-60 miles and I usually end up topping off with 5-6 gallons when I get home.
I see a lot of guys in the speed threads considering the R cars, and I wanted to have a few miles on mine before I did a write up. I really like the car overall. It has its flaws, and the typical Polaris issues, but I was expecting that going in.
I don’t feel that it’s far superior to the canned ham, they are both good cars. I prefer the Rotax drivetrain and ability to add power through tuning. But everyone in my neighborhood has a damn X3.
A long-winded overview. If anyone has any questions fire away. If anyone in the NW valley wants to meet up for a ride, hit me up.
PCI radio/comms
BD RTL chase bar
5150 whips
Switch-Pros
My impressions:
