GNEnsrud
- Feb 3, 2024
- 106
- 370
So Ive got this 94 ProV200 running pretty good, but it gives me an alarm and goes into limp mode if idle in gear for more than a minute or so.
I have already replaced the Poppet Valve. Didn’t appear to be stuck, but was the older valve design, so I put in a new seat/grommet, spring, and the newer rounded seal type of valve. Hoped this would fix the issue, since everything I found online said this was likely the issue….. nope. Problem unaffected.
Question is: what’s next? The tattletail stream is steady and strong from the moment the engine is started. My thought is to replace the thermostats at the top of each cylinder bank next. But would really like some experienced input before ai just blindly start replacing stuff.
thanks in advance for any constructive input you may have to offer.
