RZR stereo
Rbcconst
What has everyone installed?
Rockford fosgate?
JL audio?
Memphis?
Kicker?
What sub?
I want it to crank and want the bass to hit hard.
TPC
Wrenching Dad
Rockford Fosgate with two of the most powerfull amps and subs available. 8 Speakers.
spark2678
My SSV works with (5) 6.5”, 10” sub and 1 large 4 channel amp hits hard. Sounds really clean.
Rbcconst
Do you have multiple subs or the same 1 under the glove box?
lavey jr
Which model Rzr?
Ride Command?
Do you want to be able to control stereo through Ride Command or add a dedicated head unit?
Rbcconst
Which model Rzr?
Ride Command?
Rzr Velocity 4 seat. No ride command. I want it to have a separate head unit.
Ziggy
SlumLord
Mine has an SSV system and I just don't really use it. Not important to me. I may even consider offloading it.
TPC
Wrenching Dad
Multiple's under the seats.
First Thursday of the month at the Joint in Randsberg theirs a pot luck lunch and my Can Am in front blasting away.
Pivot
JL pods on rear bar. M3s. JL M3s in front by feet in SSV boxes. Kicker 10 under driver. 1 five channel amp. JL blue tooth device so no head unit at all. Use cell or tablet and spotify.
I think the JL subs beats the kicker. Not by much though.
Sub volume knob by steering wheel.
Rbcconst
Have you heard yours in comparison to the rockford fosgate systems?
Pivot
Yes. Mine is cleaner at a louder volume.
Car toyz did mine and it was close to the top fosgate set up cost.
Its real loud. Like to much loud
Rbcconst
Thats what I want! Would you do the JL sub if you were to do it again? Anything you would change?
Pivot
Mine is in a 2 seat can am. The pods are at your head so i adjusted the amp for more at my feet. In a 4 seater your back seat riders might have it loud. Bro in law has the JL 10 in the JL enclosure under driver seat. I think it hits 'tighter'. Same volume level but Id do JL. He added another JL under the other seat. Shit got real doing that.
The M3s are the boat version,so weather proof.
Amp is a phoenix gold. Pretty small and doesnt draw much power. I have a single battery.
Bass knob is critical. For sure do that. Right at my steering wheel.
The JL blue tooth connects good, no issue. I change the sound using the equalizer option on spotify. Apple has it also.
If you have a smart watch its great. I control volume and skips from my watch
TPC
Wrenching Dad
Back up camera essential in the Can Am:
SKIDMARC
I went the budget route. Got th Swamp Donkey all in one box. Sounds clean and is very loud. You can also add an amp which i
Plan to do along with maybe a couple 10’s.
Don Johnson
Don Johnson
I have the Rockford Stage 5 in my RZR and it sounds good, I would not call it loud nor is the bass output anything special. In a RZR due to very limited sub location mounting options if you want loud and big bass I think a custom system is your only real choice. In retrospect I should have had a custom setup done on mine, probably would not have cost anymore $'s and would sound way better.
Reactions: TPC
jones performance
Rockford fosgate?
JL audio?
Memphis?
Kicker?
What sub?
id go with rockford M2 speakers and probably use their pods/panels etc to add a place to mount em, but a custom sub enclosure ideally 2 subs and sound digital amps. space is very limited on the RZR's so you may not get the bass your after. the canams have a ton more avaiable space for subs and the out of hte box rockford systems sound great in them.
Reactions: TPC
Rbcconst
I will build something for sure! Not sure what brand. One of my stereo guys is pushing memphis but i don’t know anything about the brand or if he is only pushing because thats what he gets the best deal on.
Riverfamlee
I have a RF stage 5 in my can am and I put a stage 5 in my buddies RZR. The RZR kit has a little deeper bass due to the bigger box but the can am is a bit louder due to the speaker locations.
I would check out the new RF stage 6 that is coming out. They changed a few things but the biggest change is the rear pods are now 8" horn loaded. They are loud AF
Riverfamlee
I would also try and upgrade to the PMX3 head unit as it can function as a back up cam should decide to add it.
AZmike
Eastsider
I have the MB Quartz system on our 4 seat turbo Razor. Its 4 8" speakers and 1 10" sub. The front speakers are in the kick panels and the back speakers are in pods on the cage. The headunit is color and can operate a camera but I don't have one installed. I bought this kit at the off road show a couple years ago and its price compared to the Rockford system was much less. My buddies have the Rockford system and it sounds the same as the MB system
counterpart7
SSV Works. I have installed just about every kit out there and it is my favorite. JL stuff can sound a little bit better but in an open air environment, it's hard to tell.
Not a fan of the Rockford stuff at all. Overpriced and their plastic sub boxes sound like shit... SSV Works and UTV Stereo are better IMHO.
Ziggy
SlumLord
I have a bluetooth speaker I hang from the rollcage :)
I have told my wife I'd prefer to get some sort of portable bluetooth speaker.
I just moved my rear speaker pods so they're behind the rear seat headrest. Now I can see 5x more area out the back. For me the whole system is a waste of space and extra weight.
It definitely is a kick ass sound system and was very well install. Lol, when the car was being sold to me the stereo was one of their biggest selling points.....and they about busted my eardrums showing it off🤣🤣
I'm not a audiophile, but the guy I bought my RZR from had a $200 bluetooth sound bar attached to the rear seat belt bar on the cage. He did show it to me as it was not part of the sale, it sounded pretty good... well good enough for me at least. When we are out alone, I bring the little bluetooth speaker if I remember. But now I just bring my @DLC along who has a good stereo, so by extension I have a good stereo.
Ziggy
SlumLord
How much?
Dang, wish you'd have reached out a week ago when I had my cars interior tore out to install comm/c2c radio. I even thought about taking it out then but was on a time crunch. So, for time being it's staying in the car.
I was gonna say you cant sell it now.. It is holding your comms in place :)
Feelin Nauti
3 JL amps, 2 10 inch JL subs, 4 kicker 6.5 speakers,pro armor Bluetooth, honestly i wouldnt do it again as someone always has their stereo going, kind like pulling into a cove and you hear the stereo wars going on...
