Serial number help please.
94essex
Hey guys so i bought a new to 94 essex with 350. Just dont know what motor itis. i havent been able to match the serial number and its driving me nuts. I wanna order a manual so i can get to know the ins and outs. Any help would be awesome
94essex
94essex
The reason im trying to figure it out. Is the boat runs great fires right up doesnt miss, but WOT only goes to 3500 rpms which just doesnt seem right. Speedo says between 50-55 at thay. Just figured the rpm at full throttle would be closer to 4k
Fun Times
Moderated
Engine is an mercruiser ThunderBolt 4, W/PS, TWO-PC-EX, WORO 5.7L ALPHA Drive.
Your stern drive gear ratio is/would be 1.50:1 from new.
Check the speed with a GPS system say on an iPhone, etc. But if you're really reaching close to the 50ish MPH mark then your RPM should be more within your allowable 4200 - 4600 range for your engine model which would indicate your tachometer is out of adjustment at 3500.... If so then there may be an adjustment dial on the back side of the gauge that might need re-adjustment for a 8 cylinder vs 4 or 6, etc. cylinder.....Sometimes the dial just need to be turned/exercised a bit to get them working correctly again before needing a new gauge.
Here's another parts catalog for you too, http://www.mercruiserparts.com/200-2-bbl-gm-305-v-8-1987-0b525982
Merc service manual part number 90-8232251 = Manual #17, https://www.ebay.com/itm/SERVICE-MA...90-823225-1-1096-1996-BK-1-OF-2-/131780761455 .http://boatinfo.no/lib/mercruiser/manuals/mercruiser17.html#/24
94essex
Awesome thank you for the input and information. Ill climb under the dash and take a look tonight. Thanks again this site has helped me a ton already!
dezertrider
Pics of Boat? Ive been looking for my 95 essex that I wish i never sold
94essex
94essex
Just picked it up a month ago. Loving it so far
dezertrider
They built strong ass boats in the 90s. Ours was a tank. Nice and safe
94essex
Its solid i was out last weekend in some rough windy water on mead it handled good no rattles. Solid boat
SoCalDave
See if this helps.
  • Mercruiser Service Manual _17 GM V8 305 and 350 cid (5.0L 93-95) 1993 - 1997[1].pdf
