Technical: Have A Boat/Engine Question
Have a buddy with a jet bote...with a 455 Olds. (Don't deny it, we all have or have had that friend) Motor in bote froze, cracked and died. He bought a motor from a guy in Phoenix. He asked me to help put it in.
My first question to him was "what exhaust did it have on it?"
Over the transom...his boat is not.
Any ideas on how to determine if the cam will work? I know there's magic numbers, but never had to reverse engineer to find the numbers.
DarkHorseRacing
Overlap is what will get you. You can Google search “cam selection for boat to reduce water reversion” and come up with several good reads.
Nordie
Damn, they make cams big enough to cause reversion in an Olds motor?
Could you pull the timing chain cover and see the face of the cam and look for a P/N?
Mototrig
Id like to know too. I've heard it boils down to valve events and cam centerline, which many people much smarter than me can explain WAY better than I can...
The "magic" number that I've seen reoccurring for marine cams is around the 223 duration #. But there are so many other factors that can blow that number outta the water (see what I did there) haha. Basically it's all FM and no one number can explain it.
Rarely is the PN# there, it's usually on the end
I believe you can put a degree wheel on it and a dial on number 1 intake and exhaust rocker and check overlap
"There wasn't a number on the cam" was the response...I figured a pn may be a start. The thing with that, I know of about 20 cams from the 90's that I ended up with that were regrinds and just had x's...so who knows🤣
I think that's what may happen...I may have to pull the front end down and put a wheel on it...if I can find mine...it's been awhile:oops:
coolchange
Lower level functionary
Tell him to just not lift all they way after WFO.
Just tell him to convert to a Merc 4.3 /Alpha combo.
He'll get similar performance and better longevity. 😁👍
Somebody had to Olds bash here. 😁😁
Put that merc 4cyl with a 460 stroke, bore and cylinder head🤣🤣
All joking aside those run surprisingly well, maybe because it's a 230ci 4 banger😳
if the old motor is only froze broke, swap the cams and call it a day.
That would make sense...but the guy had a "mechanic" up here ring and bearing the thing, swap parts over and crap. I Had already asked him if he had the old cam, but didn't get a straight answer as to where the old motor is.
HOOTER SLED-
Supercharged MOTORBOAT!!!
In my good ole days....spun bearing was the thing.... High rev, WOT..all the oil up top. You know, fuck shit up the right way. 😂 Mondello restriction kit....10 qt marine pan, perhaps an ignition box with a rev limiter. Only way to keep them damn Olds surviving.
coolchange
Is he an Olds guy? Does it have restrictors in it now? If not do it.
mash on it
Beyond Hell Crew
@monkeyswrench -
You could measure the lift and see if Summit/Jegs has the rest of the specs in the catalog.
Just checked, Summit has ~32 different (flat tappet) cams for olds 455. Shouldn't be too hard to narrow it down.
I've been ok with 235° duration at .050" with logs and snails, 1 sbc and one bbc, if that helps.
Dan'l
rrrr
I earned my stripes a long time ago. Blew one up in 1976.
I know the guy that did the motor stuff...and I'm going to say no it doesn't. That said, not sure I want to volunteer to do it either. I should ask/warn him about it.
